Hi Sam,
sorry, I just have one Vero4K device - or do you mean another PC? - I just have a Windows PC (without kodi installed), can I test it there too?
What I did now on the Vero 4K after your last message…
sudo apt install evtest
systemctl stop mediacenter
systemctl stop eventlircd
systemctl stop system-lircd_helper.slice
…then started evtest and got this result…
No device specified, trying to scan all of /dev/input/event*
Not running as root, no devices may be available.
Available devices:
/dev/input/event0: gpio_keypad
/dev/input/event1: cec_input
/dev/input/event2: 2.4G 2.4G Wireless Device
/dev/input/event3: 2.4G 2.4G Wireless Device
/dev/input/event4: 2.4G 2.4G Wireless Device
/dev/input/event5: HBGIC Technology Co., Ltd. USB Keyboard Mouse
/dev/input/event6: HBGIC Technology Co., Ltd. USB Keyboard Mouse
/dev/input/event7: meson-ir
Select the device event number [0-7]:
… I got these results with option 5 while pushing all buttons…
Event: time 1539126490.979201, type 4 (EV_MSC), code 4 (MSC_SCAN), value 7004a
Event: time 1539126490.979201, type 1 (EV_KEY), code 102 (KEY_HOME), value 1
Event: time 1539126490.979201, -------------- SYN_REPORT ------------
Event: time 1539126491.051188, type 4 (EV_MSC), code 4 (MSC_SCAN), value 7004a
Event: time 1539126491.051188, type 1 (EV_KEY), code 102 (KEY_HOME), value 0
Event: time 1539126491.051188, -------------- SYN_REPORT ------------
Event: time 1539126493.419197, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70052
Event: time 1539126493.419197, type 1 (EV_KEY), code 103 (KEY_UP), value 1
Event: time 1539126493.419197, -------------- SYN_REPORT ------------
Event: time 1539126493.483226, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70052
Event: time 1539126493.483226, type 1 (EV_KEY), code 103 (KEY_UP), value 0
Event: time 1539126493.483226, -------------- SYN_REPORT ------------
Event: time 1539126494.403261, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70051
Event: time 1539126494.403261, type 1 (EV_KEY), code 108 (KEY_DOWN), value 1
Event: time 1539126494.403261, -------------- SYN_REPORT ------------
Event: time 1539126494.451255, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70051
Event: time 1539126494.451255, type 1 (EV_KEY), code 108 (KEY_DOWN), value 0
Event: time 1539126494.451255, -------------- SYN_REPORT ------------
Event: time 1539126494.987287, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70050
Event: time 1539126494.987287, type 1 (EV_KEY), code 105 (KEY_LEFT), value 1
Event: time 1539126494.987287, -------------- SYN_REPORT ------------
Event: time 1539126495.043260, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70050
Event: time 1539126495.043260, type 1 (EV_KEY), code 105 (KEY_LEFT), value 0
Event: time 1539126495.043260, -------------- SYN_REPORT ------------
Event: time 1539126495.499294, type 4 (EV_MSC), code 4 (MSC_SCAN), value 7004f
Event: time 1539126495.499294, type 1 (EV_KEY), code 106 (KEY_RIGHT), value 1
Event: time 1539126495.499294, -------------- SYN_REPORT ------------
Event: time 1539126495.555266, type 4 (EV_MSC), code 4 (MSC_SCAN), value 7004f
Event: time 1539126495.555266, type 1 (EV_KEY), code 106 (KEY_RIGHT), value 0
Event: time 1539126495.555266, -------------- SYN_REPORT ------------
Event: time 1539126496.027292, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70028
Event: time 1539126496.027292, type 1 (EV_KEY), code 28 (KEY_ENTER), value 1
Event: time 1539126496.027292, -------------- SYN_REPORT ------------
Event: time 1539126496.107282, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70028
Event: time 1539126496.107282, type 1 (EV_KEY), code 28 (KEY_ENTER), value 0
Event: time 1539126496.107282, -------------- SYN_REPORT ------------
… and these results with option 6 and pushing all buttons…
Event: time 1539126543.956023, type 4 (EV_MSC), code 4 (MSC_SCAN), value c0060
Event: time 1539126543.956023, type 1 (EV_KEY), code 358 (KEY_INFO), value 1
Event: time 1539126543.956023, -------------- SYN_REPORT ------------
Event: time 1539126543.964066, type 4 (EV_MSC), code 4 (MSC_SCAN), value c0060
Event: time 1539126543.964066, type 1 (EV_KEY), code 358 (KEY_INFO), value 0
Event: time 1539126543.964066, -------------- SYN_REPORT ------------
Event: time 1539126547.652120, type 4 (EV_MSC), code 4 (MSC_SCAN), value c0224
Event: time 1539126547.652120, type 1 (EV_KEY), code 158 (KEY_BACK), value 1
Event: time 1539126547.652120, -------------- SYN_REPORT ------------
Event: time 1539126547.708152, type 4 (EV_MSC), code 4 (MSC_SCAN), value c0224
Event: time 1539126547.708152, type 1 (EV_KEY), code 158 (KEY_BACK), value 0
Event: time 1539126547.708152, -------------- SYN_REPORT ------------
Event: time 1539126548.628193, type 4 (EV_MSC), code 4 (MSC_SCAN), value c00cd
Event: time 1539126548.628193, type 1 (EV_KEY), code 164 (KEY_PLAYPAUSE), value 1
Event: time 1539126548.628193, -------------- SYN_REPORT ------------
Event: time 1539126548.660181, type 4 (EV_MSC), code 4 (MSC_SCAN), value c00cd
Event: time 1539126548.660181, type 1 (EV_KEY), code 164 (KEY_PLAYPAUSE), value 0
Event: time 1539126548.660181, -------------- SYN_REPORT ------------
Event: time 1539126549.028096, type 4 (EV_MSC), code 4 (MSC_SCAN), value c0226
Event: time 1539126549.028096, type 1 (EV_KEY), code 128 (KEY_STOP), value 1
Event: time 1539126549.028096, -------------- SYN_REPORT ------------
Event: time 1539126549.092083, type 4 (EV_MSC), code 4 (MSC_SCAN), value c0226
Event: time 1539126549.092083, type 1 (EV_KEY), code 128 (KEY_STOP), value 0
Event: time 1539126549.092083, -------------- SYN_REPORT ------------
Event: time 1539126549.524219, type 4 (EV_MSC), code 4 (MSC_SCAN), value c00b4
Event: time 1539126549.524219, type 1 (EV_KEY), code 168 (KEY_REWIND), value 1
Event: time 1539126549.524219, -------------- SYN_REPORT ------------
Event: time 1539126549.604204, type 4 (EV_MSC), code 4 (MSC_SCAN), value c00b4
Event: time 1539126549.604204, type 1 (EV_KEY), code 168 (KEY_REWIND), value 0
Event: time 1539126549.604204, -------------- SYN_REPORT ------------
Event: time 1539126550.028221, type 4 (EV_MSC), code 4 (MSC_SCAN), value c00b3
Event: time 1539126550.028221, type 1 (EV_KEY), code 208 (KEY_FASTFORWARD), value 1
Event: time 1539126550.028221, -------------- SYN_REPORT ------------
Event: time 1539126550.124210, type 4 (EV_MSC), code 4 (MSC_SCAN), value c00b3
Event: time 1539126550.124210, type 1 (EV_KEY), code 208 (KEY_FASTFORWARD), value 0
Event: time 1539126550.124210, -------------- SYN_REPORT ------------
So I got still no reaction for the context menu button
What now?
