Hello, since two months a go my vero 4k + remote it get out of battery. I always turn off the vero 4k + when im not using it. I tried rebind it again without luck. its better to put the vero 4k + in sleep mode when its not in use or turn on all the time?
It may well not be the same issue, but I had a problem with battery drain in my remote - it used to get through a battery about once every three weeks. Replacing the remote was the only thing that helped. The new one has lasted about two months and is still going strong
not the same problem as OP, but Kodi notified me about the battery running out after 2 months.
Vero 4k received at the end of August, notification appeared a couple of days ago.
Is 2 months normal?
How much energy is left in the battery when “battery is running out” appears?
I noticed that the remote “flashes” the IR led even if using it with RF? Is’t it a waste of energy?
