Hi all,
Having a frustrating issue with my Vero 4K+. After playing a dozen or so movies without issue, I came across an HD MKV file that caused intermittent stuttering when viewed on my vero. Same file streamed to my raspberry pi worked without problems.
The stuttering is subtle and intermittent, took a few minutes to verify it wasn’t just a trick of the eye, but it looks almost like it’s playing at the wrong refresh rate (or as if a frame is being cut from playback every minute or so).
Any ideas? I’ve got change refresh rate to “on start/stop.” Using pass through audio. All the hardware acceleration options are turned on.
Well, logs and mediainfo can go a long way to help us help you.
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
It would be good if we could find out more about the file you are having issues playing. Please see the mediainfo section in How to submit a useful support request - General - OSMC.
You can also create the mediainfo
-output of the affected media file on the OSMC device:
- login via SSH, user
osmc
, password osmc
- if not already installed:
sudo apt-get update && sudo apt-get install mediainfo
cd
to the directory containing the video/audio material in question
- since
mediainfo
only needs to read the header information of the file data, copy the first 4 Mbytes of the media file to a new file:
dd if="<media file>" of=purgeme.bin bs=1024 count=4096
- upload the decoded media information using
mediainfo purgeme.bin|paste-log
- publish the returned URL here in this topic
- remove the created media file snippet
rm purgeme.bin
Thx for your help.
