I got the “update failed”, so I applied the appropriate hotfix ( ucawobahij
After that, it says no update is necessary. but I’m still on Oct 2020.
I then update via SSH, which seemed to work, but I’m still on Oct 2020.
I’ve noticed that there are some error messages that flash by quickly when rebooting.
logs at https://paste.osmc.tv/opalonatoq
All of my other players were fine (both Vero’s and Pi4’s.)
I suspect that the Vero has a non-volatile memory problem.
Any help would be appreciated.
Have you tried installing the latest version of OSMC from the download page?
I can check logs tomorrow.
I forgot that installing from sd was possible.
Just tried it and it worked fine.
Thanks.
Mike
Glad to hear this.
