SSHed into my Vero earlier today to get some sort of nightlight functionality enabled. Did not have too much luck, but will continue tinkering. Has anyone succeeded with getting one of these two solutions working? Or is there a way to manually adjust the color of the main display via the command line, where I can create a script to slightly automate at the specified time?
I’m guessing from a name like XFlux that it requires X11.
You might like to have a look in /sys/class/amvecm at the saturation_hue nodes. May be a steep learning curve.
