Vero 5 Internal USB Failure?
Today my remote stopped working.
dmesg | grep -i -E “usb|error|disabled”
[ 0.000443] bootconsole [aml-uart0] disabled
[ 0.449839] schedtune: disabled!
[ 0.521947] ERROR: could not get clock /cvbsout:venci_top_gate(0)
[ 0.521970] cvbs_out: error: cvbsout_clktree_probe: clk venci_top_gate
[ 0.521984] ERROR: could not get clock /cvbsout:venci_0_gate(1)
[ 0.521996] cvbs_out: error: cvbsout_clktree_probe: clk venci_0_gate
[ 0.522010] ERROR: could not get clock /cvbsout:venci_1_gate(2)
[ 0.522022] cvbs_out: error: cvbsout_clktree_probe: clk venci_1_gate
[ 0.522035] ERROR: could not get clock /cvbsout:vdac_clk_gate(3)
[ 0.522047] cvbs_out: error: cvbsout_clktree_probe: clk vdac_clk_gate
[ 0.525761] aml_iomap: write cbus reg e8 error -1
[ 0.694614] usbcore: registered new interface driver usbfs
[ 0.694655] usbcore: registered new interface driver hub
[ 0.694685] usbcore: registered new device driver usb
[ 0.706467] ERROR: could not get clock /amhdmitx:hdmi_vapb_clk(3)
[ 0.706493] ERROR: could not get clock /amhdmitx:hdmi_vpu_clk(4)
[ 0.706510] ERROR: could not get clock /amhdmitx:venci_top_gate(0)
[ 0.706532] ERROR: could not get clock /amhdmitx:venci_0_gate(1)
[ 0.706552] ERROR: could not get clock /amhdmitx:venci_1_gate(2)
[ 1.054655] audit: initializing netlink subsys (disabled)
[ 1.095378] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.095450] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.096017] usbcore: registered new interface driver cdc_acm
[ 1.096019] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.096072] usbcore: registered new interface driver usb-storage
[ 1.096174] usbcore: registered new interface driver usbserial
[ 1.096214] usbcore: registered new interface driver usbserial_generic
[ 1.096260] usbserial: USB Serial support registered for generic
[ 1.096867] usbcore: registered new interface driver uvcvideo
[ 1.096877] USB Video Class driver (1.1.1)
[ 1.097644] device-mapper: verity-avb: AVB error handler initialized with vbmeta device:
[ 1.097727] usbcore: registered new interface driver btusb
[ 1.100229] usbcore: registered new interface driver usbhid
[ 1.100231] usbhid: USB HID core driver
[ 1.138842] amlogic-new-usb2-v2 fe03a000.usb2phy: USB2 phy probe:phy_mem:0xfe03a000, iomap phy_base:0xffffff80081dd000
[ 1.139259] amlogic-new-usb3-v2 fe03a080.usb3phy: USB3 phy probe:phy_mem:0xfe03a080, iomap phy_base:0xffffff80081fe080
[ 1.289691] picdec: probe of picdec failed with error -22
[ 1.293961] aml_iomap: write cbus reg f2 error -1
[ 1.294351] aml_iomap: read cbus reg 20 error -1
[ 1.294955] aml_iomap: read cbus reg 21 error -1
[ 1.331460] aml_iomap: read cbus reg d1 error -1
[ 1.331546] aml_iomap: write cbus reg d1 error -1
[ 1.332051] aml_iomap: read cbus reg d1 error -1
[ 1.332658] aml_iomap: write cbus reg d1 error -1
[ 1.418521] request_irq error ret=-22
[ 1.421643] tee_client_open_session failed, error: 0xffff0007, origin: 0x3
[ 1.425608] snd_tdm fe330000.audiobus:tdm@2: aml_tdm_get_pins error!
[ 1.671156] tee_client_open_session failed, error: 0xffff0007, origin: 0x3
[ 1.674652] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 1.675101] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.675104] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.675107] usb usb1: Product: xHCI Host Controller
[ 1.675110] usb usb1: Manufacturer: Linux 4.9.269-93-osmc xhci-hcd
[ 1.675112] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 1.675460] hub 1-0:1.0: USB hub found
[ 1.676099] tee_client_open_session failed, error: 0xffff0007, origin: 0x3
[ 1.676496] tee_client_open_session failed, error: 0xffff0007, origin: 0x3
[ 1.676563] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 1.676646] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.676724] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.676728] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.676731] usb usb2: Product: xHCI Host Controller
[ 1.676734] usb usb2: Manufacturer: Linux 4.9.269-93-osmc xhci-hcd
[ 1.676736] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 1.677056] hub 2-0:1.0: USB hub found
[ 1.677510] tee_client_open_session failed, error: 0xffff0007, origin: 0x3
[ 1.677878] tee_client_open_session failed, error: 0xffff0007, origin: 0x3
[ 1.678253] tee_client_open_session failed, error: 0xffff0007, origin: 0x3
[ 1.678603] tee_client_open_session failed, error: 0xffff0007, origin: 0x3
[ 1.679251] dwc_otg: usb0: type: 2 speed: 0, config: 0, dma: 0, id: 0, phy: fe03a000, ctrl: 0
[ 1.679256] dwc_otg_driver_probe host only, not probe usb_otg!!!
[ 1.681000] tee_client_open_session failed, error: 0xffff0007, origin: 0x3
[ 1.681722] tee_client_open_session failed, error: 0xffff0007, origin: 0x3
[ 3.304873] tee_client_open_session failed, error: 0xffff0007, origin: 0x3
[ 3.373075] tee_client_open_session failed, error: 0xffff0007, origin: 0x3
[ 3.857798] tee_client_open_session failed, error: 0xffff0007, origin: 0x3
[ 3.869540] tee_client_open_session failed, error: 0xffff0007, origin: 0x3
[ 3.901139] tee_client_open_session failed, error: 0xffff0007, origin: 0x3
[ 7.481714] stmmac: Energy-Efficient Ethernet intentionally disabled
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
I have no usb hardware receiver for the remote.
I also did a dist-upgrade from commandline because I saw “Update Available” in the bottom left. That message is still there after the commandline update.
Hello, please send a short email to support@osmc.tv – include where you purchased the Vero, your order number, the approximate date of purchase, and a link to this thread.
Please do not attempt to open the Vero device!
Apologies for the inconvenience, and thank you in advance for your efforts.
I’ve had the same issue recently too - as have some others.
There’s some history in the thread here, including some recent submissions.
I sent an email to support at OSMC on October the 28th of October. Have not received any response yet.
Thanks for your email. I’m up to date on all emails up to 28/10, I will check now (was travelling yesterday).
I’ve found your email dated 29/10 and have given you a response, let me know if you haven’t received it.
I see the email.
Here is the log https://paste.osmc.tv/vemiraviwi
Thank your for the provided log set. Unfortunately the system journal only only covers the last minute or seeems to be corrupt:
Please, can you try with a new clean journal log?
sudo journalctl --rotate
sudo journalctl --vacuum-time=1s
sudo reboot
and collect a log set again? Thanks in advance for your efforts.
An alternative method to get rid off the current journal file is
sudo systemctl stop systemd-journald
sudo rm -rf /run/log/journal/*
sudo systemctl start systemd-journald
sudo reboot
Try these Logs available at https://paste.osmc.tv/tojomovezo
The deafening silence hurts and says so much.
Apologies – but I’ve been responding to you via email and not this forum. I like to keep things in one place. Whichever you prefer is fine by me.
For the avoidance of doubt, I re-sent my correspondence to you
