Vero Fast Forward, Skip Question
Haven’t found anything, so i started a new topic.
Have a Vero 4K+ since 2019 and just bought the Vero 5.
Everything is fine, well, almost. There is an issue when i use Fast Forward/Skip.
The audio is ok, but the picture freezes for a few seconds.
Not everytime, but often and also with different files (all via NFS and NAS).
Just wondering if there is any solution. And, this didn’t happen with my old Vero till i applied an update! :slight_smile:
Thx and sorry for typos, i am not a native english speaker.
We are aware of this.
It will be fixed in an update next week. If you’d prefer, I can give you instructions to manually apply it now.
Hi Sam,
and thanks for your answer. I can wait, but maybe someone wants to know, so, if its not too effortful just tell us… :slight_smile:
Hopefully the issue is now addressed
  1. Login via the command line
  2. Run the following command to add the staging repository:
  3. Run the following commands to update: sudo apt-get update && sudo apt-get dist-upgrade && reboot
  4. Your system should have have received the update.
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
This will deactivate the staging repository. You can do so with the following command:
sudo rm /etc/apt/sources.list.d/osmc-devel.list.
Thanks again.
But, cant access the vero via ssh, port 22: Connection refused
Found this thread: Can't enable SSH - #17 by sam_nazarko
So, i will wait, dont want to reinstall Osmc. :slight_smile:
Edit: Worked. Compared the IP from my IP-Scanner (…0.4) and the one from the Vero System Info Screen (…0.44). Could connect with the IP Address from the Vero System Info and applied the update.
Quick Test looks good.
THANK YOU SAM
Has that update been released yet?
No - all updates are documented on the blog
