I have a Vero 4k+ with latest updates and everything and it works perfectly.
However; I have noticed that if I physically place the Vero device near my router (a few inches, almost touching the router) that WiFi from my router gradually (in the span of 1 minute) becomes incredibly bad and the internet performance becomes poor. I go from 200mbps on my Iphone’s speed test to around 20-30 Mbps. I’ve tried different speed tests and different apps and it’s noticeable everywhere, even tried different devices with WiFi and it all happens consistently.
I have tried 3 different Mikrotik routers (hAP ac lite, hAP ac, and some older model). I have tried both 2.4ghz and 5ghz, no difference at all. I also disabled the WiFi on my Vero, I am only using a wired connection.
Luckily the solution is incredibly simple; I moved the Vero device 2 meters away from the router and WiFi now works perfectly. I can easily reproduce the issue every time without fail.
Anyone have any idea what could possibly be the issue? I have never seen this occur with any other device before and it took me 3 routers to get to the bottom of the issue. I had WiFi issues for a few months now and I couldn’t for the life of me figure it out.
