Good morning,
I want to play a 98GB 4k video on my SD card.
When I format my SD in NTFS, it accepts the 4K file but does not appear in Kodi
When I format my SD in ext, I can’t transfer my 4k file because Windows tells me my file is too heavy.
Thank you in advance for your help
Did you give the partition a label?
Do you mean exFAT?
Sorry… Yes.
I just formatted under Windows NTFS with the name “SD”
Then it should auto mount under /media/SD
If that is not the case provide logs.
I’m sorry, but I’m a french beginner…
How to provide logs ?
reboot the OSMC device
reproduce the issue
upload the log set either using the
Are you putting the files on the SD card in Windows or over the network? If you did that over the network then the partition on your SD card is probably corrupted. If this is the case I would recommend installing MiniTool Partition Wizard and use that to delete the current partition and create a new one formatted as either NTFS or ext4 (If you choose ext4 it will not be usable in Windows but it will work in the Vero).
I reformatted my windows SD to NTFS and then to ext3 and I managed to copy a 4k file to it.
