Vero V Bluetooth Audio
When I connect both my hearing aids via My OSMC bluetooth they appear as paired devices, but I cannot hear any audio.
They do not appear as Audio Output Devices in System/Audio.
What have I missed? Is there a straight forward solution?
But are they ‘connected’?
I have re-connected them to no avail.
Have you looked through this?
Often you can solve this by removing and forgetting the BT device and re-pairing and connecting either in MyOSMC or (better, since it gives you some feedback) using bluetoothctl.
I did look through the above.
On closer observation when connecting after having been discovered I get a pop message telling me connection has failed.
I guess my Widex Moment hearing aid works on a smart phone, but OSMC is not compatible.
Oh well can’t have everything!
Could be we don’t support the codec it uses. If you want to persevere, debug logs would be a good next step.
