Vero V crashes during playback - WIFI connected
Let’s give it the weekend. If things stay stable then I’ll consider it fixed.
Pushed a final update – do update, but expect things to stay working..
For now, I’m guessing no news is good news..
From here, no time today, so no news is no news. Will try to test tomorrow.
Fair. Have a good weekend and let me know how you get on
Tested again with the newest build, and everything still continues to work (I hope that was the expectation).
It was indeed.
Will wait for some feedback from @chris8?
Passed the “acid test”.
Fantastic, cleaned up all the branch which is why I repushed yesterday. Issue seems finally nailed
The annoying thing is I got very very close to fixing it in August 2024 but missed one thing.
I’ll roll it out shortly. Nothing to do further on your side and appreciate your testing.
Both you and @Oberon : if you need another device at any point, even if it’s for a friend or family member, contact sam@osmc.tv and I’ll knock a chunk of change off.
I can only apologise for how long this took to fix. It wasn’t an easy bug to fix because I could never reproduce it. Fortunately after building out the crash infrastructure it became easier to diagnose. It will no doubt be useful again in the future.
Thanks, Sam, really appreciate your tenacity in identifying and solving this issue, especially as you couldn’t reproduce it yourself. And agreed, the crash infrastructure will surely make future troubleshooting much easier for other issues. It’s also better for the device to reboot itself when frozen than to require a power cycle.
Out of curiosity, what was the key change that solved the issue?
Thank you kindly for the offer as well. Showing off the Vero V with friends will be easier now that it doesn’t freeze all the time, haha.
The wife’s also happy with me, having removed the unsightly network cable - which is a great win :slight_smile:
The Vero V’s WiFi chip uses a driver that its vendor wrote and tested for a different software platform than the one the Vero V runs. That driver makes assumptions about how incoming WiFi data is handed from the driver up into the system — and on our platform those assumptions don’t hold.
Under sustained WiFi traffic (which is exactly what high-bitrate playback is), that mismatch could wedge a CPU completely, which is the freeze you were seeing. It was never Dolby Vision or a particular file — the errors people spotted in logs were a side effect of the freeze starting, not the cause.
The reason this took so long to pin down: when it happened the device locked solid — no network, no remote. So the only way out was pulling the power, which also erased the diagnostic information the system keeps in memory. Every freeze destroyed its own evidence. So the first job wasn’t fixing it, it was making it visible: adding crash-capture that survives a reboot, and making a freeze turn itself into an automatic reboot-with-a-log instead of a dead box. It then turned out that the ramoops infrastructure we added recently wasn’t enough to capture this specific kind of issue. So more changes were needed..
Once that was in and affected users sent those logs, the fault finally showed itself in the WiFi receive path and it became clear that the various settings tried over the years had each only moved the problem, because the whole receive mechanism was the wrong fit, not any one option.
The fix routes all WiFi traffic through the system’s own standard receive path by using the one actually built for this platform instead of the driver’s. It’s a focused change, but it only became the obvious one once the evidence pointed exactly here.
I am grateful for the quick testing and logs that you and @chris8 provided. This is now fixed and will be in the next update.
Thank you for the fix @sam_nazarko
I will put in an order for a new Vero shortly :slight_smile:
//Thomas
Hi Sam, is the main branch updated with this code in the meantime, or do we still need to stick with these dev/staging builds for now?
This is still in staging.
Glad I found this thread and that this was sorted out. I’m on the latest public release (OSMC 2026.05-2) and given the dates here in this thread, I’m assuming my version does not have the fix for the issue?
I’m fine updating to the staging version but I think I read in another thread here somewhere that it’s currently crashing when bringing up the OSD or something. Is there an ETA for the next public release/update?
The May release does not have the fix for the issue.
We will have an update which does soon
