Vero V stops playback on Dolby Vision HEVC remux
Playback stops and Kodi returns to GUI. Source is NFS from 192.168.1.15. Kernel log shows repeated ammvdec_h265 vdec_release/vdec_create and Dolby metadata parser errors:
DOLBY ERROR: metadata parser process fail.
File is 2160p HEVC Dolby Vision/HDR10+ remux.
https://paste.osmc.tv/ibesekojaq
Thanks in advance :slight_smile:
Update:
The Vero V is entering Dolby Vision correctly during playback.
HDMI config during playback:
3840x2160p24hz
RGB 8-bit
DV type DV-Std
dmesg shows:
Creating Dolby Vision metadata parser instance success
DV:[0,8441683000,12,DOVI,544,0]
But later it starts throwing repeated Dolby parser errors:
DOLBY ERROR: meta(194), pts64(…) → parser process fail
DOLBY ERROR: meta(194), pts64(…) → metadata parser process fail
After that, the decoder is released and the HDMI output switches back to SDR:
vdec_release instance
Dolby VSIF, switching signal to SDR
outputmode changed to 1080p60hz
So this does not look like an EDID/NFS issue. Dolby Vision starts successfully, but the metadata parser fails during playback.
Full logs update:
https://paste.osmc.tv/unixoxumah
Does this happen with any DV file?
Please post debug logs so we can see better what Kodi is doing.
Can you upload a sample of the problem file, please?
