Vero V stuck on May 2026 update
Hello,
My Vero has been really reliable but one issue I continue to have is it won’t update past the May 26 update. It just gives an error with a red X and won’t DL the rest of the update and I have to reboot it to get it usable again.
Any quick way to fix this or am i looking at a wipe rebuild or some other long drawn out process to get it on a current update?
Ideally I’dlike to just DL the update to a usb stick and have the device update it from there.
Hi, have you installed the updates2026fix as described here?
Thanks, that fixed it
