Vero4k+ loses wired connection
Hi there , lately I have had all kind of issues/ crashes with vero , mostly related with internet connection , first I use vpn and time to time when streaming a remux it was losing connection to vpn after playing a movie for a min, then once restarted all fine.
But today it’s losing the wired connection and losing the assigned IP, sometimes I get the message no wired connection or it does assign a random IP (169…) no internet.
I managed to get the correct ip after unplug box , cables etc but it came back again.
Any idea about what can I do in order to resolve this ?! I have also restarted kodi , box etc but seems to not resolve , I do get internet on wireless if I connect ( usually disabled )
Have you tried changing the ethernet cable?
  • upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
https://paste.osmc.tv/uleqavuwej
cable isnt problem, as i tested with other devices.
I have restarted router etc but still the same, i managed to get internet in the box for a couple of minutes via wired connection.
Please try another cable if you can.
Otherwise, I recommend cleaning the contacts of the Ethernet port.
I think problem is on my end, I am having problems with my Ethernet port , it works it stops to work. Anyway thanks.
