I just received my new Vero4k+ and was so excited to start using it, but it has gotten stuck on the initial boot/setup and won’t proceed
See screenshot below for what I’m seeing. It’s just been stuck on this screen for 10 minutes or so… What do I do? And why isn’t it completing the initial setup?
Thanks @ActionA, I’ll give that a go
How do I turn it off? Is it safe to just pull the power plug?
Is it best to use the 2018.12-1 or 2019.04-1 image?
I’m trying to reinstall by using a USB, but the installer won’t let me select anything other than SD
. The other options are there, but everything is greyed out.
EDIT:
I selected SD and then it allowed me to select my USB
. Ahh well it’s working now
Yes, it is working now. Successfully installed and booted. Thank you very much @ActionA for your quick response!
What is your order number? This issue was fixed some time ago.
Ok – the issue has since been resolved.
Thanks Sam. All good. I received it mid last week, but have only gotten around to getting it setup now. I appreciate the fast response and follow up from you and the team.
