I am getting audio and video stutter on a video file. Strange thing is that I watched a part of this video months ago and just today wanted to continue watching. It used to run fine.
File is HEVC 4k with DD audio stream
OSMC Vero 4K+ connected to a receiver (DD and DTS capable) via HDMI which is then connected to my tv. Passthrough enabled
Files on a Synology NAS, connected with gigabit ethernet (rebooted NAS and OSMC just to be sure as well)
Can’t remember changing settings but might be wrong as some time has passed. Have played many other files fine, and there were likely some OSMC updates in between viewing sessions.
Full log attached. First playing the video file (resuming), then playing another part of the documentary series from the start (to rule out a resume issue).
Both files play fine on my laptop (wifi connected where OSMC is wired)
Would need full logs (via MyOSMC) and also with Debug logging activated.
reproduce the issue
It is a Synology DS214Play. SMB3 is activated (SMB2 minimum), see screenshot
Curious, does it look like a throughput issue of some kind? These logs have so many entries.
In Kodi minimimum protocol version is “none” and Max. is SMBv3 - should I raise this minimum?
I noticed that you seem to have automatic library scanning turned on, and while you were watching A Perfect Planet: Volcano that the scan was running. It may be with watching the video and scanning the library that your network is being overwhelmed. Try turning off the automatic scanning and see if that helps.
Thanks. Yes just rechecked the specs, it is a Marantz NR-1508 and listed with support for: “Dolby TrueHD and DTS-HD Master Audio”. Even so I also disabled passthrough for testing and that doesn’t help.
You are right on the library scanning, on most tries it wasn’t scanning, exactly when I was making the log it was. I was somehow under the assumption these activities are paused when playing. On all other attempts to play the file no library scanning was taking place. Even so I disabled it just to be sure however that doesn’t work.
Are there any clues in the log as to where the issue may be found? network connectivity? strange video format? video and or audio decoding issues?
You have your speaker setup to 2.0. I’d expect to see that as 5.1 or 7.1.
The audio in the file you are trying to play appears to be E-AC3. The audio in my copy of the same file (I ripped from disc) is Atmos. If there are multiple audio tracks do you have a correct one selected?
Thanks. I still had 2.0 speaker setup from a while ago when I used spdif. Now all is via hdmi so thanks for spotting, changed to 4.0 which is what I currently have. Should only matter when not using passthrough?
Checked the file again, I only have one audiotrack.
Strange, perhaps I should just forget about this one and move on.
You still want to set the proper channels (4.0 if that’s your speaker setup) even when using passthrough.
If you have other Atmos or DTS-X files to test with it may help narrow down the problem. If it’s only happen on the Perfect Planet videos it may be that they are just a bad rip.
Thanks. I have discarded some files in the past however this one used to play and plays on laptop and Mi box s (kodi). Will try to find some more test files and discard this one.
Update: problem solved! Replaced hdmi cable between osmc and receiver and all is well again. So issue all on my side and nothing to do with osmc. Thanks to everyone for investigating.
