On my vero4k, up to date running kodi 19, a particular media file causes the screen to go blank after a few seconds, but the audio continues to play. If I skip ahead/back briefly it returns but then disappears again after a few seconds of playing. Other media work fine. The problem file works fine on a linux desktop running mpv. Here is the mediainfo output:
General
Unique ID : 173261525105315824354199922563285501141 (0x8258F4B88D86ED299DAD379CA57FC4D5)
Complete name : Cowboy.Bebop.S01E01.mkv
Format : Matroska
Format version : Version 1
File size : 379 MiB
Duration : 24 min 42 s
Overall bit rate : 2 146 kb/s
Encoded date : UTC 2008-05-23 23:35:31
Writing application : mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:26
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Attachments : pakenham free.ttf / annifont.ttf / Belgothk.ttf / BellGo_B.ttf / butterbrotpapier.ttf / GAMBLER.TTF / Imperator.ttf / OFFEBB__.TTF
Video
Format : AVC
Format profile : High@L5.1
Format settings : CABAC / 16 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 1 500 kb/s
Width : 704 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Original display aspect ratio : 3:2
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.185
Stream size : 259 MiB (68%)
Title : Session #1: Asteroid Blues
Writing library : x264 core 59 r826 138601d
Encoding settings : cabac=1 / ref=16 / deblock=1:0:0 / analyse=0x3:0x113 / me=tesa / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=1500 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00
Language : Japanese
Default : Yes
Forced : No
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 79.2 MiB (21%)
Title : 6ch Dolby AC3
Language : Japanese
Service kind : Complete Main
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Bit rate : 192 kb/s
Channel(s) : 2 channels
Bit depth : 16 bits
Stream size : 33.9 MiB (9%)
Title : 2ch Dolby AC3
Language : English
Default : No
Forced : No
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Title : Styled Subs (ASS)
Language : English
Default : Yes
Forced : No
I can provide the file or run tests, just let me know.
Thanks,
