Video Freezes But Audio is Normal
Hi. Ran into videos x265 1080p where video freezes on the first frame, but audio continues playing normally. Then after around 15-20 seconds the screen would show the next still picture on the screen all while audio is playing normally. The Vero isn’t locked so I can skip forward, stop, etc. Using Vero 4K+ with 2020.03-1 firmware.
Log is here - https://paste.osmc.tv/qomagulije
Sample of video is here - https://drive.google.com/open?id=19GNIBk6L1u145s0zdS2pnz8xgEf3OXgX
Media Info is here:
General
Unique ID : 218756291184286521954728699712680632788 (0xA492EDDE2ECE9CF3882E39665E8A21D4)
Complete name : [AnimeRG] Boruto (2015) Naruto the Movie [1080p] [x265] [pseudo].mkv
Format : Matroska
Format version : Version 4
File size : 1.38 GiB
Duration : 1 h 35 min
Overall bit rate : 2 071 kb/s
Encoded date : UTC 2016-07-20 15:16:54
Writing application : mkvmerge v9.2.0 (‘Photograph’) 64bit
Writing library : libebml v1.3.3 + libmatroska v1.4.4
Attachments : OpenSans-Semibold.ttf
Video
Format : HEVC
Format profile : Main@L5@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 1 740 kb/s
Width : 1 904 pixels
Height : 1 024 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.037
Stream size : 1.16 GiB (84%)
Default : Yes
Forced : No
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Bit rate : 265 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Delay relative to video : 20 ms
Stream size : 179 MiB (13%)
Title : Japanese 5.1 Surround
Language : Japanese
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Bit rate : 65 b/s
Count of elements : 1093
Stream size : 45.9 KiB (0%)
Title : (SRT)
Language : Arabic
Default : No
Forced : No
Text #2
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Duration : 1 h 32 min
Bit rate : 80 b/s
Count of elements : 1085
Compression mode : Lossless
Stream size : 55.0 KiB (0%)
Title : English (ASS)
Language : English
Default : Yes
Forced : No
Text #3
Format : UTF-8
Bit rate : 68 b/s
Count of elements : 1314
Stream size : 46.4 KiB (0%)
Title : English (SRT)
Language : English
Default : No
Forced : No
Text #4
Format : UTF-8
Bit rate : 77 b/s
Count of elements : 1309
Stream size : 54.3 KiB (0%)
Title : (SRT)
Language : Indonesian
Default : No
Forced : No
Text #5
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Bit rate : 73.4 kb/s
Count of elements : 6342
Stream size : 48.8 MiB (3%)
Title : (BD)
Language : Japanese
Default : No
Forced : No
Text #6
Format : UTF-8
Duration : 1 h 34 min
Bit rate : 51 b/s
Count of elements : 1063
Stream size : 36.0 KiB (0%)
Title : (SRT)
Language : Malayalam
Default : No
Forced : No
Text #7
Format : UTF-8
Bit rate : 51 b/s
Count of elements : 1008
Stream size : 34.7 KiB (0%)
Title : (SRT)
Language : Spanish
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:02:57.844 : en:Chapter 02
00:06:51.411 : en:Chapter 03
00:11:30.147 : en:Chapter 04
00:14:51.807 : en:Chapter 05
00:18:37.116 : en:Chapter 06
00:22:01.486 : en:Chapter 07
00:33:18.454 : en:Chapter 08
00:45:09.331 : en:Chapter 09
00:48:25.444 : en:Chapter 10
00:56:13.370 : en:Chapter 11
01:04:44.380 : en:Chapter 12
01:11:56.979 : en:Chapter 13
01:16:21.076 : en:Chapter 14
01:21:43.899 : en:Chapter 15
01:25:50.353 : en:Chapter 16
01:29:50.385 : en:Chapter 17
01:34:22.239 : en:Chapter 18
01:35:18.713 : en:Chapter 19
Does this happen every time on the same videos?
I have seen this every once in a while, but stopping and starting the video again fixes it, and it doesn’t seem to be fixed to a few specific videos…it appears to be random.
yes. everytime. tried it on libreelec 8.2.5 (kodi 17) and it works fine.
Which community build of LibreELEC are you running on the Vero?
NVM, I realised you’re probably testing LE on a Pi. It won’t be an exact like for like comparison duetothe hardware differences.
Can you test it on the 4.9 builds?
will do Sam.
actually using wetek hub (s905) LE 8.2.5 official kernel 3.14.29. Build: kodi 17.6 Git:a9a7a20. compiled Apr 13 2018
Hi Sam. Different outcome on the 4.9 kernel. It buffers while screen showing the OSMC logo animation. No audio too. Only a timer that shows it’s playing.
Log is here - https://paste.osmc.tv/ehawaxalun
I will share this same log on the 4.9 testing thread.
Okay. We have some improvements for buffering that will be made available soon. It may be fixed when we make those changes available
thanks Sam!
