UPDATE! I think I fixed it! All I did is update Handbrake to latest version.
Now I only tested it using the preview. I am now creating full file and I will update to let you know the result.
Update #2 Everything works fine now! However the video sometimes run slow but that’s due to RPi’s limitation. I plan to order RPi 2 to fix this.
Original post below.
I’m using RPi B. I have strange problem I never seen before. The video file in question works fine on PC. But when i play it on RPi I get this green stuff on bottom half of screen. see image http://i.imgur.com/upnQQBF.jpg
I ripped the file from Star Trek TNG bluray and compressed it using handbrake. I never had this problem with any other files in the past that I created using handbrake.
Here’s what I tested.
Raw MKV file from MakeMkv works fine on RPi.
Created MKV file from Handbrake using High profile and normal profile. Still same result.
The strange thing is that the first episode Encounter at Farpoint file created from Handbrake works fine. Only other episodes does not work right.
Here’s the mediainfo copied from MPC-HC.
Encounter at Farpoint file:
General
Unique ID : 20604027687562500456832973041585705766 (0xF8030FEECC97DCF16B27CB52FD15326)
Complete name : E:\movies\Star Trek The Next Generation\Season 1\Star Trek Tng - 1x1 - Encounter At Farpoint.mkv
Format : Matroska
Format version : Version 2
File size : 6.27 GiB
Duration : 1h 31mn
Overall bit rate : 9 819 Kbps
Writing application : HandBrake 0.9.9
Writing library : libmkv 0.6.5
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 31mn
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 130 r2273 b3065e6
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Duration : 1h 31mn
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 1h 31mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Bit depth : 16 bits
Stream size : 418 MiB (7%)
Language : English
Default : No
Forced : No
Text
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : Chapter 1
00:01:44.313 : Chapter 2
00:07:06.217 : Chapter 3
00:14:35.625 : Chapter 4
00:27:29.273 : Chapter 5
00:36:01.076 : Chapter 6
00:47:09.660 : Chapter 7
00:57:02.878 : Chapter 8
01:06:20.018 : Chapter 9
01:11:42.673 : Chapter 10
01:18:24.158 : Chapter 11
01:30:17.370 : Chapter 12
and the next episode that don’t work:
General
Unique ID : 41938864507309010067243584569212994432 (0x1F8D21A9E8264C5347D453DE57210380)
Complete name : E:\movies\Star Trek The Next Generation\Season 1\Star Trek Tng - 1x3 - The Naked Now.mkv
Format : Matroska
File size : 5.57 GiB
Duration : 45mn 33s
Overall bit rate : 17.5 Mbps
Video
Format : AVC
Format settings, ReFrames : 3 frames
Duration : 45mn 33s
Width : 1 920 pixels
Height : 1 440 pixels
Color space : YUV
Bit depth : 8 bits
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio #1
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 45mn 33s
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 45mn 33s
Bit rate : 640 Kbps
Bit depth : 16 bits
Stream size : 209 MiB (4%)
Language : English
Default : No
Forced : No
Text
Format : PGS
Language : English
Default : Yes
Forced : No
Menu
00:05:51.726 : Chapter 2
00:13:15.586 : Chapter 3
00:21:55.314 : Chapter 4
00:29:01.365 : Chapter 5
00:37:11.104 : Chapter 6
00:44:43.598 : Chapter 7
Any idea what’s wrong?
