I’m trying to create an OpenVPN server with my raspberry pi, and when I connect using OpenVPN GUI on my computer, I get Sun Aug 14 19:53:02 2016 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Sun Aug 14 19:53:02 2016 TLS Error: TLS handshake failed
Will I be better off just getting rid of everything that I did for vpn and start over? If yes, I need instructions on how to reinstall whatever sudo apt-get install -y openvpn easy-rsa installed, if it’s okay to delete some scripts I made, if it’s okay to delete the easy-rsa folder, and how to reset iptables.
I’ll also need accurate instructions on how to setup openvpn on a Debian server and a Windows 10 client. It’ll be easier on me if I undid everything.
(I have Teamviewer if you want to look at how messed up everything is through SSH or VNC)
Well I don’t think you need to uninstall/reinstall anything. Openvpn is relative straight forward (single config file and some keys). You can start from scratch with an empty key folder in easy-rsa if you want to.
In terms of instructions the openvpn pages are quite well written with good examples:
So I just do cd /etc/openvpn/easy-rsa, and do source ./vars and ./clean-all, and then delete the scripts I made? How do I reset and use iptables, because that might be messed up too.
If you look at the end of the article there are links to the other 3 posts in his series including a very good guide on how to troubleshoot what may not work.
I followed it to the letter and it works flawlessly for me.
