I have vpnc installed on osmc and it worked very well until the latest Release on May 25.
It does look like the tun module is not supported/loaded anymore.
/usr/sbin/vpnc: can’t open /dev/net/tun, check that it is either device char 10 200 or (with DevFS) a symlink to …/misc/net/tun (not misc/net/tun): No such device
/usr/sbin/vpnc: can’t initialise tunnel interface: No such device
I checked with modprobe tun:
> modprobe: ERROR: …/libkmod/libkmod-index.c:822 index_mm_open() magic check fail: 0 instead of b007f457
modprobe: ERROR: ../libkmod/libkmod.c:557 kmod_search_moddep() could not open moddep file '/lib/modules/4.9.29-6-osmc/modules.dep.bin' modprobe: FATAL: Module tun not found.
Checked if i could find any modules:
find /lib/modules/ -iname ‘tun.ko.gz’
no results
Any ideas?
