Roll back with:
sudo apt-get install $(awk ‘$1 == “2020-08-11” && $3 == “upgrade” {print $4"="$5}’ /var/log/dpkg.log | tr ‘\n’ ’ ')
and
sudo apt-get install $(awk ‘$1 == “2020-08-07” && $3 == “upgrade” {print $4"="$5}’ /var/log/dpkg.log | tr ‘\n’ ’ ')
If you want to have a dry run add “-s” to the apt-get command.
You’ll have to examine your dpkg.log for the proper date. I was too lazy to work the package(s) out, which causes the malfunc with livestreaming, including PVR and youtube. Rolling back and everything is working as before.
regards,
stefan
Which update are you referring to? We haven’t released an update for a while now.
It’s from the OS. Running sudo apt-get update && sudo apt-get dist-upgrade will pull some new files from the repos. This is what I rolled back:
2020-08-13 17:54:09 startup archives unpack
2020-08-13 17:54:10 upgrade python-pil:armhf 4.0.0-4+deb9u2 4.0.0-4+deb9u1
2020-08-13 17:54:10 status half-configured python-pil:armhf 4.0.0-4+deb9u2
2020-08-13 17:54:10 status unpacked python-pil:armhf 4.0.0-4+deb9u2
2020-08-13 17:54:10 status half-installed python-pil:armhf 4.0.0-4+deb9u2
2020-08-13 17:54:11 status half-installed python-pil:armhf 4.0.0-4+deb9u2
2020-08-13 17:54:11 status unpacked python-pil:armhf 4.0.0-4+deb9u1
2020-08-13 17:54:12 upgrade python-imaging:all 4.0.0-4+deb9u2 4.0.0-4+deb9u1
2020-08-13 17:54:12 status half-configured python-imaging:all 4.0.0-4+deb9u2
2020-08-13 17:54:12 status unpacked python-imaging:all 4.0.0-4+deb9u2
2020-08-13 17:54:12 status half-installed python-imaging:all 4.0.0-4+deb9u2
2020-08-13 17:54:12 status unpacked python-imaging:all 4.0.0-4+deb9u1
2020-08-13 17:54:12 upgrade wpasupplicant:armhf 2:2.4-1+deb9u7 2:2.4-1+deb9u6
2020-08-13 17:54:12 status half-configured wpasupplicant:armhf 2:2.4-1+deb9u7
2020-08-13 17:54:12 status unpacked wpasupplicant:armhf 2:2.4-1+deb9u7
2020-08-13 17:54:12 status half-installed wpasupplicant:armhf 2:2.4-1+deb9u7
2020-08-13 17:54:12 status triggers-pending dbus:armhf 1.10.32-0+deb9u1
2020-08-13 17:54:13 status triggers-pending dbus:armhf 1.10.32-0+deb9u1
2020-08-13 17:54:13 status half-installed wpasupplicant:armhf 2:2.4-1+deb9u7
2020-08-13 17:54:13 status unpacked wpasupplicant:armhf 2:2.4-1+deb9u6
2020-08-13 17:54:13 startup packages configure
2020-08-13 17:54:13 configure wpasupplicant:armhf 2:2.4-1+deb9u6
2020-08-13 17:54:13 status half-configured wpasupplicant:armhf 2:2.4-1+deb9u6
2020-08-13 17:54:13 status installed wpasupplicant:armhf 2:2.4-1+deb9u6
2020-08-13 17:54:13 trigproc dbus:armhf 1.10.32-0+deb9u1
2020-08-13 17:54:13 status half-configured dbus:armhf 1.10.32-0+deb9u1
2020-08-13 17:54:13 status installed dbus:armhf 1.10.32-0+deb9u1
2020-08-13 17:54:13 configure python-pil:armhf 4.0.0-4+deb9u1
2020-08-13 17:54:13 status unpacked python-pil:armhf 4.0.0-4+deb9u1
2020-08-13 17:54:13 status half-configured python-pil:armhf 4.0.0-4+deb9u1
2020-08-13 17:54:15 status installed python-pil:armhf 4.0.0-4+deb9u1
2020-08-13 17:54:15 configure python-imaging:all 4.0.0-4+deb9u1
2020-08-13 17:54:15 status unpacked python-imaging:all 4.0.0-4+deb9u1
2020-08-13 17:54:15 status half-configured python-imaging:all 4.0.0-4+deb9u1
2020-08-13 17:54:15 status installed python-imaging:all 4.0.0-4+deb9u1
2020-08-13 17:54:34 startup archives unpack
2020-08-13 17:54:34 upgrade e2fslibs:armhf 1.43.4-2+deb9u2 1.43.4-2+deb9u1
2020-08-13 17:54:34 status triggers-pending libc-bin:armhf 2.24-11+deb9u4
2020-08-13 17:54:34 status half-configured e2fslibs:armhf 1.43.4-2+deb9u2
2020-08-13 17:54:34 status unpacked e2fslibs:armhf 1.43.4-2+deb9u2
2020-08-13 17:54:34 status half-installed e2fslibs:armhf 1.43.4-2+deb9u2
2020-08-13 17:54:35 status half-installed e2fslibs:armhf 1.43.4-2+deb9u2
2020-08-13 17:54:35 status unpacked e2fslibs:armhf 1.43.4-2+deb9u1
2020-08-13 17:54:35 startup packages configure
2020-08-13 17:54:35 configure e2fslibs:armhf 1.43.4-2+deb9u1
2020-08-13 17:54:35 status half-configured e2fslibs:armhf 1.43.4-2+deb9u1
2020-08-13 17:54:35 status installed e2fslibs:armhf 1.43.4-2+deb9u1
2020-08-13 17:54:35 startup archives unpack
2020-08-13 17:54:36 upgrade e2fsprogs:armhf 1.43.4-2+deb9u2 1.43.4-2+deb9u1
2020-08-13 17:54:36 status half-configured e2fsprogs:armhf 1.43.4-2+deb9u2
2020-08-13 17:54:36 status unpacked e2fsprogs:armhf 1.43.4-2+deb9u2
2020-08-13 17:54:36 status half-installed e2fsprogs:armhf 1.43.4-2+deb9u2
2020-08-13 17:54:37 status half-installed e2fsprogs:armhf 1.43.4-2+deb9u2
2020-08-13 17:54:37 status unpacked e2fsprogs:armhf 1.43.4-2+deb9u1
2020-08-13 17:54:37 startup packages configure
2020-08-13 17:54:37 configure e2fsprogs:armhf 1.43.4-2+deb9u1
2020-08-13 17:54:38 status unpacked e2fsprogs:armhf 1.43.4-2+deb9u1
2020-08-13 17:54:38 status half-configured e2fsprogs:armhf 1.43.4-2+deb9u1
2020-08-13 17:54:38 status installed e2fsprogs:armhf 1.43.4-2+deb9u1
2020-08-13 17:54:38 startup archives unpack
2020-08-13 17:54:38 upgrade libcomerr2:armhf 1.43.4-2+deb9u2 1.43.4-2+deb9u1
2020-08-13 17:54:38 status half-configured libcomerr2:armhf 1.43.4-2+deb9u2
2020-08-13 17:54:38 status unpacked libcomerr2:armhf 1.43.4-2+deb9u2
2020-08-13 17:54:38 status half-installed libcomerr2:armhf 1.43.4-2+deb9u2
2020-08-13 17:54:38 status unpacked libcomerr2:armhf 1.43.4-2+deb9u1
2020-08-13 17:54:39 startup packages configure
2020-08-13 17:54:39 configure libcomerr2:armhf 1.43.4-2+deb9u1
2020-08-13 17:54:39 status unpacked libcomerr2:armhf 1.43.4-2+deb9u1
2020-08-13 17:54:45 status half-configured libcomerr2:armhf 1.43.4-2+deb9u1
2020-08-13 17:54:45 status installed libcomerr2:armhf 1.43.4-2+deb9u1
2020-08-13 17:54:46 startup archives unpack
2020-08-13 17:54:46 upgrade libss2:armhf 1.43.4-2+deb9u2 1.43.4-2+deb9u1
2020-08-13 17:54:46 status half-configured libss2:armhf 1.43.4-2+deb9u2
2020-08-13 17:54:46 status unpacked libss2:armhf 1.43.4-2+deb9u2
2020-08-13 17:54:46 status half-installed libss2:armhf 1.43.4-2+deb9u2
2020-08-13 17:54:47 status unpacked libss2:armhf 1.43.4-2+deb9u1
2020-08-13 17:54:47 startup packages configure
2020-08-13 17:54:47 configure libss2:armhf 1.43.4-2+deb9u1
2020-08-13 17:54:47 status half-configured libss2:armhf 1.43.4-2+deb9u1
2020-08-13 17:54:47 status installed libss2:armhf 1.43.4-2+deb9u1
2020-08-13 17:54:47 startup archives unpack
2020-08-13 17:54:48 upgrade curl:armhf 7.52.1-5+deb9u11 7.52.1-5+deb9u10
2020-08-13 17:54:48 status half-configured curl:armhf 7.52.1-5+deb9u11
2020-08-13 17:54:48 status unpacked curl:armhf 7.52.1-5+deb9u11
2020-08-13 17:54:48 status half-installed curl:armhf 7.52.1-5+deb9u11
2020-08-13 17:54:48 status unpacked curl:armhf 7.52.1-5+deb9u10
2020-08-13 17:54:48 upgrade libcurl3:armhf 7.52.1-5+deb9u11 7.52.1-5+deb9u10
2020-08-13 17:54:48 status half-configured libcurl3:armhf 7.52.1-5+deb9u11
2020-08-13 17:54:48 status unpacked libcurl3:armhf 7.52.1-5+deb9u11
2020-08-13 17:54:48 status half-installed libcurl3:armhf 7.52.1-5+deb9u11
2020-08-13 17:54:49 status half-installed libcurl3:armhf 7.52.1-5+deb9u11
2020-08-13 17:54:49 status unpacked libcurl3:armhf 7.52.1-5+deb9u10
2020-08-13 17:54:49 upgrade ffmpeg:armhf 7:3.2.15-0+deb9u1 7:3.2.14-1~deb9u1
2020-08-13 17:54:49 status half-configured ffmpeg:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:49 status unpacked ffmpeg:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:49 status half-installed ffmpeg:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:50 status half-installed ffmpeg:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:50 status unpacked ffmpeg:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:54:50 upgrade libavdevice57:armhf 7:3.2.15-0+deb9u1 7:3.2.14-1~deb9u1
2020-08-13 17:54:50 status half-configured libavdevice57:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:50 status unpacked libavdevice57:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:50 status half-installed libavdevice57:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:51 status unpacked libavdevice57:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:54:51 upgrade libavfilter6:armhf 7:3.2.15-0+deb9u1 7:3.2.14-1~deb9u1
2020-08-13 17:54:51 status half-configured libavfilter6:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:51 status unpacked libavfilter6:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:51 status half-installed libavfilter6:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:51 status unpacked libavfilter6:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:54:51 upgrade libswscale4:armhf 7:3.2.15-0+deb9u1 7:3.2.14-1~deb9u1
2020-08-13 17:54:51 status half-configured libswscale4:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:51 status unpacked libswscale4:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:51 status half-installed libswscale4:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:52 status unpacked libswscale4:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:54:52 upgrade libavformat57:armhf 7:3.2.15-0+deb9u1 7:3.2.14-1~deb9u1
2020-08-13 17:54:52 status half-configured libavformat57:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:52 status unpacked libavformat57:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:52 status half-installed libavformat57:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:52 status unpacked libavformat57:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:54:52 upgrade libavcodec57:armhf 7:3.2.15-0+deb9u1 7:3.2.14-1~deb9u1
2020-08-13 17:54:52 status half-configured libavcodec57:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:52 status unpacked libavcodec57:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:52 status half-installed libavcodec57:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:54 status half-installed libavcodec57:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:54 status unpacked libavcodec57:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:54:55 upgrade libswresample2:armhf 7:3.2.15-0+deb9u1 7:3.2.14-1~deb9u1
2020-08-13 17:54:55 status half-configured libswresample2:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:55 status unpacked libswresample2:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:55 status half-installed libswresample2:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:55 status unpacked libswresample2:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:54:55 upgrade libpostproc54:armhf 7:3.2.15-0+deb9u1 7:3.2.14-1~deb9u1
2020-08-13 17:54:55 status half-configured libpostproc54:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:55 status unpacked libpostproc54:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:55 status half-installed libpostproc54:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:55 status unpacked libpostproc54:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:54:55 upgrade libavresample3:armhf 7:3.2.15-0+deb9u1 7:3.2.14-1~deb9u1
2020-08-13 17:54:55 status half-configured libavresample3:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:56 status unpacked libavresample3:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:56 status half-installed libavresample3:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:56 status unpacked libavresample3:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:54:56 upgrade libx11-data:all 2:1.6.4-3+deb9u2 2:1.6.4-3+deb9u1
2020-08-13 17:54:56 status half-configured libx11-data:all 2:1.6.4-3+deb9u2
2020-08-13 17:54:56 status unpacked libx11-data:all 2:1.6.4-3+deb9u2
2020-08-13 17:54:56 status half-installed libx11-data:all 2:1.6.4-3+deb9u2
2020-08-13 17:54:57 status half-installed libx11-data:all 2:1.6.4-3+deb9u2
2020-08-13 17:54:57 status unpacked libx11-data:all 2:1.6.4-3+deb9u1
2020-08-13 17:54:57 upgrade libx11-6:armhf 2:1.6.4-3+deb9u2 2:1.6.4-3+deb9u1
2020-08-13 17:54:57 status half-configured libx11-6:armhf 2:1.6.4-3+deb9u2
2020-08-13 17:54:57 status unpacked libx11-6:armhf 2:1.6.4-3+deb9u2
2020-08-13 17:54:57 status half-installed libx11-6:armhf 2:1.6.4-3+deb9u2
2020-08-13 17:54:58 status half-installed libx11-6:armhf 2:1.6.4-3+deb9u2
2020-08-13 17:54:58 status unpacked libx11-6:armhf 2:1.6.4-3+deb9u1
2020-08-13 17:54:58 upgrade libavutil55:armhf 7:3.2.15-0+deb9u1 7:3.2.14-1~deb9u1
2020-08-13 17:54:58 status half-configured libavutil55:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:58 status unpacked libavutil55:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:58 status half-installed libavutil55:armhf 7:3.2.15-0+deb9u1
2020-08-13 17:54:58 status unpacked libavutil55:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:54:58 upgrade libopenmpt0:armhf 0.2.7386~beta20.3-3+deb9u4 0.2.7386~beta20.3-3+deb9u3
2020-08-13 17:54:58 status half-configured libopenmpt0:armhf 0.2.7386~beta20.3-3+deb9u4
2020-08-13 17:54:58 status unpacked libopenmpt0:armhf 0.2.7386~beta20.3-3+deb9u4
2020-08-13 17:54:58 status half-installed libopenmpt0:armhf 0.2.7386~beta20.3-3+deb9u4
2020-08-13 17:54:58 status unpacked libopenmpt0:armhf 0.2.7386~beta20.3-3+deb9u3
2020-08-13 17:54:59 upgrade libssh-gcrypt-4:armhf 0.7.3-2+deb9u3 0.7.3-2+deb9u2
2020-08-13 17:54:59 status half-configured libssh-gcrypt-4:armhf 0.7.3-2+deb9u3
2020-08-13 17:54:59 status unpacked libssh-gcrypt-4:armhf 0.7.3-2+deb9u3
2020-08-13 17:54:59 status half-installed libssh-gcrypt-4:armhf 0.7.3-2+deb9u3
2020-08-13 17:54:59 status unpacked libssh-gcrypt-4:armhf 0.7.3-2+deb9u2
2020-08-13 17:54:59 upgrade ffmpeg-doc:all 7:3.2.15-0+deb9u1 7:3.2.14-1~deb9u1
2020-08-13 17:54:59 status half-configured ffmpeg-doc:all 7:3.2.15-0+deb9u1
2020-08-13 17:54:59 status unpacked ffmpeg-doc:all 7:3.2.15-0+deb9u1
2020-08-13 17:54:59 status half-installed ffmpeg-doc:all 7:3.2.15-0+deb9u1
2020-08-13 17:55:07 status half-installed ffmpeg-doc:all 7:3.2.15-0+deb9u1
2020-08-13 17:55:07 status unpacked ffmpeg-doc:all 7:3.2.14-1~deb9u1
2020-08-13 17:55:08 upgrade libjpeg62-turbo:armhf 1:1.5.1-2+deb9u1 1:1.5.1-2
2020-08-13 17:55:08 status half-configured libjpeg62-turbo:armhf 1:1.5.1-2+deb9u1
2020-08-13 17:55:08 status unpacked libjpeg62-turbo:armhf 1:1.5.1-2+deb9u1
2020-08-13 17:55:08 status half-installed libjpeg62-turbo:armhf 1:1.5.1-2+deb9u1
2020-08-13 17:55:08 upgrade librsvg2-common:armhf 2.40.21-0+deb9u1 2.40.16-1+b1
2020-08-13 17:55:08 status half-configured librsvg2-common:armhf 2.40.21-0+deb9u1
2020-08-13 17:55:08 status unpacked librsvg2-common:armhf 2.40.21-0+deb9u1
2020-08-13 17:55:08 status half-installed librsvg2-common:armhf 2.40.21-0+deb9u1
2020-08-13 17:55:08 status triggers-pending libgdk-pixbuf2.0-0:armhf 2.36.5-2+deb9u2
2020-08-13 17:55:09 status half-installed librsvg2-common:armhf 2.40.21-0+deb9u1
2020-08-13 17:55:09 status unpacked librsvg2-common:armhf 2.40.16-1+b1
2020-08-13 17:55:09 upgrade librsvg2-2:armhf 2.40.21-0+deb9u1 2.40.16-1+b1
2020-08-13 17:55:09 status half-configured librsvg2-2:armhf 2.40.21-0+deb9u1
2020-08-13 17:55:09 status unpacked librsvg2-2:armhf 2.40.21-0+deb9u1
2020-08-13 17:55:09 status half-installed librsvg2-2:armhf 2.40.21-0+deb9u1
2020-08-13 17:55:09 status unpacked librsvg2-2:armhf 2.40.16-1+b1
2020-08-13 17:55:09 upgrade libssh-4:armhf 0.7.3-2+deb9u3 0.7.3-2+deb9u2
2020-08-13 17:55:09 status half-configured libssh-4:armhf 0.7.3-2+deb9u3
2020-08-13 17:55:09 status unpacked libssh-4:armhf 0.7.3-2+deb9u3
2020-08-13 17:55:09 status half-installed libssh-4:armhf 0.7.3-2+deb9u3
2020-08-13 17:55:09 status unpacked libssh-4:armhf 0.7.3-2+deb9u2
2020-08-13 17:55:09 upgrade libx11-xcb1:armhf 2:1.6.4-3+deb9u2 2:1.6.4-3+deb9u1
2020-08-13 17:55:09 status half-configured libx11-xcb1:armhf 2:1.6.4-3+deb9u2
2020-08-13 17:55:09 status unpacked libx11-xcb1:armhf 2:1.6.4-3+deb9u2
2020-08-13 17:55:09 status half-installed libx11-xcb1:armhf 2:1.6.4-3+deb9u2
2020-08-13 17:55:10 status half-installed libx11-xcb1:armhf 2:1.6.4-3+deb9u2
2020-08-13 17:55:10 status unpacked libx11-xcb1:armhf 2:1.6.4-3+deb9u1
2020-08-13 17:55:10 startup packages configure
2020-08-13 17:55:10 configure ffmpeg-doc:all 7:3.2.14-1~deb9u1
2020-08-13 17:55:10 status unpacked ffmpeg-doc:all 7:3.2.14-1~deb9u1
2020-08-13 17:55:10 status half-configured ffmpeg-doc:all 7:3.2.14-1~deb9u1
2020-08-13 17:55:10 status installed ffmpeg-doc:all 7:3.2.14-1~deb9u1
2020-08-13 17:55:10 configure libjpeg62-turbo:armhf 1:1.5.1-2
2020-08-13 17:55:10 status unpacked libjpeg62-turbo:armhf 1:1.5.1-2
2020-08-13 17:55:10 status half-configured libjpeg62-turbo:armhf 1:1.5.1-2
2020-08-13 17:55:10 status installed libjpeg62-turbo:armhf 1:1.5.1-2
2020-08-13 17:55:10 configure librsvg2-2:armhf 2.40.16-1+b1
2020-08-13 17:55:10 status unpacked librsvg2-2:armhf 2.40.16-1+b1
2020-08-13 17:55:10 status half-configured librsvg2-2:armhf 2.40.16-1+b1
2020-08-13 17:55:10 status installed librsvg2-2:armhf 2.40.16-1+b1
2020-08-13 17:55:10 configure libopenmpt0:armhf 0.2.7386~beta20.3-3+deb9u3
2020-08-13 17:55:10 status unpacked libopenmpt0:armhf 0.2.7386~beta20.3-3+deb9u3
2020-08-13 17:55:10 status half-configured libopenmpt0:armhf 0.2.7386~beta20.3-3+deb9u3
2020-08-13 17:55:10 status installed libopenmpt0:armhf 0.2.7386~beta20.3-3+deb9u3
2020-08-13 17:55:10 configure libcurl3:armhf 7.52.1-5+deb9u10
2020-08-13 17:55:10 status unpacked libcurl3:armhf 7.52.1-5+deb9u10
2020-08-13 17:55:10 status half-configured libcurl3:armhf 7.52.1-5+deb9u10
2020-08-13 17:55:10 status installed libcurl3:armhf 7.52.1-5+deb9u10
2020-08-13 17:55:10 configure libssh-gcrypt-4:armhf 0.7.3-2+deb9u2
2020-08-13 17:55:10 status unpacked libssh-gcrypt-4:armhf 0.7.3-2+deb9u2
2020-08-13 17:55:10 status half-configured libssh-gcrypt-4:armhf 0.7.3-2+deb9u2
2020-08-13 17:55:10 status installed libssh-gcrypt-4:armhf 0.7.3-2+deb9u2
2020-08-13 17:55:10 configure librsvg2-common:armhf 2.40.16-1+b1
2020-08-13 17:55:10 status unpacked librsvg2-common:armhf 2.40.16-1+b1
2020-08-13 17:55:10 status half-configured librsvg2-common:armhf 2.40.16-1+b1
2020-08-13 17:55:10 status triggers-awaited librsvg2-common:armhf 2.40.16-1+b1
2020-08-13 17:55:10 configure libx11-xcb1:armhf 2:1.6.4-3+deb9u1
2020-08-13 17:55:10 status half-configured libx11-xcb1:armhf 2:1.6.4-3+deb9u1
2020-08-13 17:55:10 status installed libx11-xcb1:armhf 2:1.6.4-3+deb9u1
2020-08-13 17:55:10 trigproc libc-bin:armhf 2.24-11+deb9u4
2020-08-13 17:55:10 status half-configured libc-bin:armhf 2.24-11+deb9u4
2020-08-13 17:55:11 status installed libc-bin:armhf 2.24-11+deb9u4
2020-08-13 17:55:11 configure libssh-4:armhf 0.7.3-2+deb9u2
2020-08-13 17:55:11 status triggers-pending libc-bin:armhf 2.24-11+deb9u4
2020-08-13 17:55:11 status unpacked libssh-4:armhf 0.7.3-2+deb9u2
2020-08-13 17:55:11 status half-configured libssh-4:armhf 0.7.3-2+deb9u2
2020-08-13 17:55:11 status installed libssh-4:armhf 0.7.3-2+deb9u2
2020-08-13 17:55:11 configure libx11-data:all 2:1.6.4-3+deb9u1
2020-08-13 17:55:11 status unpacked libx11-data:all 2:1.6.4-3+deb9u1
2020-08-13 17:55:11 status half-configured libx11-data:all 2:1.6.4-3+deb9u1
2020-08-13 17:55:11 status installed libx11-data:all 2:1.6.4-3+deb9u1
2020-08-13 17:55:11 configure curl:armhf 7.52.1-5+deb9u10
2020-08-13 17:55:11 status unpacked curl:armhf 7.52.1-5+deb9u10
2020-08-13 17:55:11 status half-configured curl:armhf 7.52.1-5+deb9u10
2020-08-13 17:55:11 status installed curl:armhf 7.52.1-5+deb9u10
2020-08-13 17:55:11 configure libx11-6:armhf 2:1.6.4-3+deb9u1
2020-08-13 17:55:11 status unpacked libx11-6:armhf 2:1.6.4-3+deb9u1
2020-08-13 17:55:11 status half-configured libx11-6:armhf 2:1.6.4-3+deb9u1
2020-08-13 17:55:11 status installed libx11-6:armhf 2:1.6.4-3+deb9u1
2020-08-13 17:55:11 configure libavutil55:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:11 status unpacked libavutil55:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:11 status half-configured libavutil55:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:11 status installed libavutil55:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:11 trigproc libgdk-pixbuf2.0-0:armhf 2.36.5-2+deb9u2
2020-08-13 17:55:11 status half-configured libgdk-pixbuf2.0-0:armhf 2.36.5-2+deb9u2
2020-08-13 17:55:11 status installed librsvg2-common:armhf 2.40.16-1+b1
2020-08-13 17:55:11 status installed libgdk-pixbuf2.0-0:armhf 2.36.5-2+deb9u2
2020-08-13 17:55:11 configure libswresample2:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:11 status unpacked libswresample2:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:11 status half-configured libswresample2:armhf 7:3.2.14-1~deb9u1
2020-08-11 21:13:55 status unpacked wpasupplicant:armhf 2:2.4-1+deb9u7
2020-08-11 21:13:55 startup packages configure
2020-08-13 17:55:11 status installed libpostproc54:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:11 configure libavresample3:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:11 status unpacked libavresample3:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:11 status half-configured libavresample3:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:11 status installed libavresample3:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:11 configure libavcodec57:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:11 status unpacked libavcodec57:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:11 status half-configured libavcodec57:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:11 status installed libavcodec57:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:11 configure libavformat57:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:11 status unpacked libavformat57:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:12 status half-configured libavformat57:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:12 status installed libavformat57:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:12 configure libavfilter6:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:12 status unpacked libavfilter6:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:12 status half-configured libavfilter6:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:12 status installed libavfilter6:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:12 configure libavdevice57:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:12 status unpacked libavdevice57:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:12 status half-configured libavdevice57:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:12 status installed libavdevice57:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:12 configure ffmpeg:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:12 status unpacked ffmpeg:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:12 status half-configured ffmpeg:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:12 status installed ffmpeg:armhf 7:3.2.14-1~deb9u1
2020-08-13 17:55:12 trigproc libc-bin:armhf 2.24-11+deb9u4
2020-08-13 17:55:12 status half-configured libc-bin:armhf 2.24-11+deb9u4
2020-08-13 17:55:12 status installed libc-bin:armhf 2.24-11+deb9u4
regards,
stefan
Those are all from the Debian repo – and none from the OSMC repo – so I’m not sure what you are suggesting. Clearly, it’s unrealistic to propose that people stop updating their devices.
Particularly from a single report.
AFAIK the debian repo is in the sources.list per default. Hmm, not quite sure, you should know better. I confess, I never used the “official way” initiating an update via My OSMC. Therefore I don’t know what happens if people are choosing this way.
@dillthedog
I agree, people won’t stop updating. I’m not suggesting anything.
@sam_nazarko
Yes, it’s a single report. Feel free to test on your own. Or simply wait if more reports are coming in. I just wanted to show a way to roll back to a working status. That’s all.
regards,
stefan
it’s strange… I also use this command:
sudo apt-get update && sudo apt-get -y -f dist-upgrade
for update my OSMC on my Pi2… I usually do a manual check every 2 or 3 days and i just checked and i didn’t find all these packages to install…
Perhaps that’s because you run updates frequently.
Here’s what I see on my Vero4K:
osmc@osmc-4k:~$ sudo apt-get dist-upgrade --dry-run
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
base-files ca-certificates curl dbus e2fslibs e2fsprogs libcomerr2 libcups2 libcurl3 libcurl3-gnutls libdbus-1-3 libgnutls30 libjpeg62-turbo libmariadbclient18
libperl5.24 libpython3.5-minimal libpython3.5-stdlib librsvg2-2 librsvg2-common libsnmp-base libsnmp30 libss2 libssh-4 libx11-6 libx11-data libx11-dev
libx11-xcb-dev libx11-xcb1 linux-libc-dev nfs-common perl perl-base perl-modules-5.24 python-imaging python-pil python3.5 python3.5-minimal qemu qemu-system
qemu-system-arm qemu-system-common qemu-system-mips qemu-system-misc qemu-system-ppc qemu-system-sparc qemu-system-x86 qemu-user qemu-user-static qemu-utils tzdata
vero3-mediacenter-osmc wpasupplicant
52 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
That’s 52 packges to upgrade.
dillthedog:
all can be possible… I have probably installed them all but a little at a time.
anyway when talk about “livestream” it’s a bit generic… for example I often follow some livestream via youtube and some livestream via twitch used their addons and apparently I don’t notice any particular problems.
