Here is my dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.27-7-osmc (root@vero2a) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Tue Jan 24 03:38:31 UTC 2017
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x2e400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 80bd6380, node_mem_map add64000
[ 0.000000] Normal zone: 1692 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9660->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @aefaa000 s23552 r8192 d21504 u53248
[ 0.000000] pcpu-alloc: s23552 r8192 d21504 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 190820
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2709.boardrev=0xa21041 bcm2709.serial=0x5e65121a smsc95xx.macaddr=B8:27:EB:65:12:1A bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p7 osmcdev=rbp2 rootfstype=ext4 rootwait quiet
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 741044K/770048K available (8022K kernel code, 440K rwdata, 1872K rodata, 1792K init, 764K bss, 20812K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xaf800000 - 0xff800000 (1280 MB)
lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x809b1dc8 (9896 kB)
.init : 0x809b2000 - 0x80b72000 (1792 kB)
.data : 0x80b72000 - 0x80be0074 ( 441 kB)
.bss : 0x80be3000 - 0x80ca23ec ( 765 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000011] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000031] Switching to timer-based delay loop, resolution 52ns
[ 0.000333] Console: colour dummy device 80x30
[ 0.000553] console [tty0] enabled
[ 0.000580] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000610] pid_max: default: 32768 minimum: 301
[ 0.000956] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000976] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002208] Disabling cpuset control group subsystem
[ 0.002259] Initializing cgroup subsys io
[ 0.002293] Initializing cgroup subsys memory
[ 0.002349] Initializing cgroup subsys devices
[ 0.002375] Initializing cgroup subsys freezer
[ 0.002399] Initializing cgroup subsys net_cls
[ 0.002469] CPU: Testing write buffer coherency: ok
[ 0.002551] ftrace: allocating 19464 entries in 58 pages
[ 0.049873] CPU0: update cpu_capacity 1024
[ 0.049909] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.049924] [bcm2709_smp_prepare_cpus] enter
[ 0.050074] Setting up static identity map for 0x8240 - 0x8298
[ 0.129449] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.129803] [bcm2709_secondary_init] enter cpu:1
[ 0.129860] CPU1: update cpu_capacity 1024
[ 0.129869] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.159475] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.159763] [bcm2709_secondary_init] enter cpu:2
[ 0.159793] CPU2: update cpu_capacity 1024
[ 0.159801] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.189560] [bcm2709_boot_secondary] cpu:3 started (0) 16
[ 0.189814] [bcm2709_secondary_init] enter cpu:3
[ 0.189843] CPU3: update cpu_capacity 1024
[ 0.189851] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.189944] Brought up 4 CPUs
[ 0.189974] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.189984] CPU: All CPU(s) started in HYP mode.
[ 0.189993] CPU: Virtualization extensions available.
[ 0.190923] devtmpfs: initialized
[ 0.203517] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.204012] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.205130] pinctrl core: initialized pinctrl subsystem
[ 0.205935] NET: Registered protocol family 16
[ 0.211383] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.239710] cpuidle: using governor ladder
[ 0.269742] cpuidle: using governor menu
[ 0.277098] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.277117] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.277315] Serial: AMBA PL011 UART driver
[ 0.277634] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.278341] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.353286] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ 0.353903] SCSI subsystem initialized
[ 0.354141] usbcore: registered new interface driver usbfs
[ 0.354254] usbcore: registered new interface driver hub
[ 0.354414] usbcore: registered new device driver usb
[ 0.359989] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-01-25 17:53
[ 0.387057] clocksource: Switched to clocksource arch_sys_counter
[ 0.439680] FS-Cache: Loaded
[ 0.440098] CacheFiles: Loaded
[ 0.456578] NET: Registered protocol family 2
[ 0.457888] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.458027] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.458220] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.458349] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.458414] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.458752] NET: Registered protocol family 1
[ 0.459292] RPC: Registered named UNIX socket transport module.
[ 0.459308] RPC: Registered udp transport module.
[ 0.459319] RPC: Registered tcp transport module.
[ 0.459330] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.572201] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.574664] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.574866] audit: initializing netlink subsys (disabled)
[ 0.574943] audit: type=2000 audit(0.539:1): initialized
[ 0.590628] VFS: Disk quotas dquot_6.6.0
[ 0.591017] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.593604] FS-Cache: Netfs 'nfs' registered for caching
[ 0.594866] NFS: Registering the id_resolver key type
[ 0.594935] Key type id_resolver registered
[ 0.594948] Key type id_legacy registered
[ 0.598439] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.598648] io scheduler noop registered
[ 0.599246] io scheduler bfq registered (default)
[ 0.599258] BFQ I/O-scheduler version: v7r7
[ 0.602215] BCM2708FB: allocated DMA memory ee800000
[ 0.602260] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.664139] Console: switching to colour frame buffer device 240x67
[ 0.704186] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.704328] vc-cma: Videocore CMA driver
[ 0.704341] vc-cma: vc_cma_base = 0x00000000
[ 0.704353] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.704364] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.704689] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 0.725879] brd: module loaded
[ 0.737460] loop: module loaded
[ 0.738670] vchiq: vchiq_init_state: slot_zero = 0xae880000, is_master = 0
[ 0.740611] Loading iSCSI transport class v2.0-870.
[ 0.741739] usbcore: registered new interface driver smsc95xx
[ 0.741824] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.942245] Core Release: 2.80a
[ 0.942281] Setting default values for core params
[ 0.942311] Finished setting default values for core params
[ 1.142756] Using Buffer DMA mode
[ 1.142772] Periodic Transfer Interrupt Enhancement - disabled
[ 1.142783] Multiprocessor Interrupt Enhancement - disabled
[ 1.142796] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.142814] Dedicated Tx FIFOs mode
[ 1.143287] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xae814000 dma = 0xee814000 len=9024
[ 1.143332] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 1.143364] dwc_otg: Microframe scheduler enabled
[ 1.143442] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x8057f240
[ 1.143462] WARN::hcd_init_fiq:414: FIQ ASM at 0x8057f5b0 length 36
[ 1.143481] WARN::hcd_init_fiq:439: MPHI regs_base at 0xaf87e000
[ 1.143575] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.143631] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.143688] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 1.143745] Init: Port Power? op_state=1
[ 1.143756] Init: Power Port (0)
[ 1.144095] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.144116] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.144133] usb usb1: Product: DWC OTG Controller
[ 1.144148] usb usb1: Manufacturer: Linux 4.4.27-7-osmc dwc_otg_hcd
[ 1.144164] usb usb1: SerialNumber: 3f980000.usb
[ 1.145380] hub 1-0:1.0: USB hub found
[ 1.145458] hub 1-0:1.0: 1 port detected
[ 1.146280] dwc_otg: FIQ enabled
[ 1.146293] dwc_otg: NAK holdoff enabled
[ 1.146303] dwc_otg: FIQ split-transaction FSM enabled
[ 1.146341] Module dwc_common_port init
[ 1.146781] usbcore: registered new interface driver usb-storage
[ 1.147289] mousedev: PS/2 mouse device common for all mice
[ 1.147944] usbcore: registered new interface driver usbtouchscreen
[ 1.148326] bcm2835-cpufreq: min=600000 max=900000
[ 1.150954] sdhci: Secure Digital Host Controller Interface driver
[ 1.150962] sdhci: Copyright(c) Pierre Ossman
[ 1.151272] sdhost: log_buf @ ae813000 (ee813000)
[ 1.207202] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.227529] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.228058] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.228224] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.228399] usbcore: registered new interface driver usbhid
[ 1.228407] usbhid: USB HID core driver
[ 1.228886] Initializing XFRM netlink socket
[ 1.228921] NET: Registered protocol family 17
[ 1.229082] Key type dns_resolver registered
[ 1.229230] Registering SWP/SWPB emulation handler
[ 1.230092] registered taskstats version 1
[ 1.230280] vc-sm: Videocore shared memory driver
[ 1.230295] [vc_sm_connected_init]: start
[ 1.230865] [vc_sm_connected_init]: end - returning 0
[ 1.231129] of_cfs_init
[ 1.231230] of_cfs_init: OK
[ 1.234156] Freeing unused kernel memory: 1792K (809b2000 - 80b72000)
[ 1.265123] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.267420] mmc0: new high speed SDHC card at address 0001
[ 1.268503] mmcblk0: mmc0:0001 SD8GB 7.32 GiB
[ 1.278893] mmcblk0: p1 p2 < p5 p6 p7 >
[ 1.337243] Indeed it is in host mode hprt0 = 00021501
[ 1.476443] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 1.487567] fsck: E2fsck run: /bin/e2fsck -p -C 0 /dev/mmcblk0p7
[ 1.487811] fsck: Filesystem UUID: b04ebfb8-13f4-4021-9736-4797553c3b4d
[ 1.488052] fsck: root-rbp2: clean, 48999/465120 files, 776313/1858560 blocks
[ 1.517172] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.517396] Indeed it is in host mode hprt0 = 00001101
[ 1.717441] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.717478] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.718358] hub 1-1:1.0: USB hub found
[ 1.718480] hub 1-1:1.0: 5 ports detected
[ 1.997190] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.097656] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.097690] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.101115] smsc95xx v1.0.4
[ 2.161453] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:65:12:1a
[ 4.195695] random: systemd: uninitialized urandom read (16 bytes read, 67 bits of entropy available)
[ 4.200181] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 4.200740] systemd[1]: Detected architecture 'arm'.
[ 4.268467] NET: Registered protocol family 10
[ 4.270562] systemd[1]: Inserted module 'ipv6'
[ 4.282362] systemd[1]: Set hostname to <osmc-royston>.
[ 4.445217] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 67 bits of entropy available)
[ 4.688072] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available)
[ 4.689702] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available)
[ 4.691344] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available)
[ 4.729917] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available)
[ 4.730883] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available)
[ 4.731107] random: systemd: uninitialized urandom read (16 bytes read, 69 bits of entropy available)
[ 4.817218] random: systemd: uninitialized urandom read (16 bytes read, 70 bits of entropy available)
[ 4.817383] random: systemd: uninitialized urandom read (16 bytes read, 70 bits of entropy available)
[ 5.026478] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 5.026831] systemd[1]: Found ordering cycle on basic.target/start
[ 5.026865] systemd[1]: Found dependency on sysinit.target/start
[ 5.026892] systemd[1]: Found dependency on kbd.service/start
[ 5.026919] systemd[1]: Found dependency on remote-fs.target/start
[ 5.026944] systemd[1]: Found dependency on remote-fs-pre.target/start
[ 5.026969] systemd[1]: Found dependency on connman.service/start
[ 5.026994] systemd[1]: Found dependency on dbus.service/start
[ 5.027018] systemd[1]: Found dependency on basic.target/start
[ 5.027178] systemd[1]: Breaking ordering cycle by deleting job kbd.service/start
[ 5.027215] systemd[1]: Job kbd.service/start deleted to break ordering cycle starting with basic.target/start
[ 5.027652] systemd[1]: Found ordering cycle on basic.target/start
[ 5.027686] systemd[1]: Found dependency on sysinit.target/start
[ 5.027714] systemd[1]: Found dependency on rpcbind.service/start
[ 5.027742] systemd[1]: Found dependency on network-online.target/start
[ 5.027767] systemd[1]: Found dependency on network.target/start
[ 5.027792] systemd[1]: Found dependency on connman.service/start
[ 5.027816] systemd[1]: Found dependency on dbus.service/start
[ 5.027840] systemd[1]: Found dependency on basic.target/start
[ 5.027866] systemd[1]: Breaking ordering cycle by deleting job rpcbind.service/start
[ 5.027897] systemd[1]: Job rpcbind.service/start deleted to break ordering cycle starting with basic.target/start
[ 5.031110] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 5.031558] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.031796] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 5.032467] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.032625] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[ 5.032926] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 5.033020] systemd[1]: Starting Paths.
[ 5.033118] systemd[1]: Reached target Paths.
[ 5.033206] systemd[1]: Starting Encrypted Volumes.
[ 5.033294] systemd[1]: Reached target Encrypted Volumes.
[ 5.033393] systemd[1]: Starting Swap.
[ 5.033483] systemd[1]: Reached target Swap.
[ 5.033571] systemd[1]: Expecting device dev-mmcblk0p6.device...
[ 5.033665] systemd[1]: Starting Root Slice.
[ 5.033863] systemd[1]: Created slice Root Slice.
[ 5.033957] systemd[1]: Starting User and Session Slice.
[ 5.034279] systemd[1]: Created slice User and Session Slice.
[ 5.034375] systemd[1]: Starting Delayed Shutdown Socket.
[ 5.034634] systemd[1]: Listening on Delayed Shutdown Socket.
[ 5.034730] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 5.034997] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 5.035091] systemd[1]: Starting Journal Socket (/dev/log).
[ 5.035374] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.035495] systemd[1]: Starting udev Control Socket.
[ 5.035714] systemd[1]: Listening on udev Control Socket.
[ 5.035828] systemd[1]: Starting udev Kernel Socket.
[ 5.035996] systemd[1]: Listening on udev Kernel Socket.
[ 5.036104] systemd[1]: Starting Journal Socket.
[ 5.036362] systemd[1]: Listening on Journal Socket.
[ 5.036512] systemd[1]: Starting System Slice.
[ 5.036811] systemd[1]: Created slice System Slice.
[ 5.036918] systemd[1]: Starting Restore / save the current clock...
[ 5.078160] systemd[1]: Starting udev Coldplug all Devices...
[ 5.082253] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.097998] systemd[1]: Starting Load Kernel Modules...
[ 5.116683] systemd[1]: Started Set Up Additional Binary Formats.
[ 5.116889] systemd[1]: Mounted Huge Pages File System.
[ 5.117715] systemd[1]: Mounting Debug File System...
[ 5.121791] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 5.125895] systemd[1]: Starting LSB: NFS support files common to client and server...
[ 5.130382] systemd[1]: Starting Journal Service...
[ 5.135474] systemd[1]: Started Journal Service.
[ 5.212160] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[ 5.365935] fuse init (API version 7.23)
[ 5.589335] systemd-udevd[175]: starting version 215
[ 6.065603] lirc_dev: IR Remote Control driver registered, major 244
[ 6.107138] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 6.109211] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 6.116013] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.827865] FAT-fs (mmcblk0p6): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 7.077412] lirc_rpi: auto-detected active high receiver on GPIO pin 18
[ 7.078189] lirc_rpi lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
[ 7.078212] lirc_rpi: driver registered!
[ 7.804312] input: lircd as /devices/virtual/input/input0
[ 8.197925] systemd-journald[152]: Received request to flush runtime journal from PID 1
[ 8.692041] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 8.692476] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.253444] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 10.306011] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 10.307920] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 10.361316] 8021q: 802.1Q VLAN Support v1.8
[ 10.641149] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 14.438579] random: nonblocking pool is initialized
[ 17.030017] Console: switching to colour dummy device 80x30
I don’t see any pulse, just the response to the button press.
I have forwarded my receipt to sales@
Thanks again
