Watched/not watched flag
Within KODI on an Android device, a long press on a file name brings up a menu which includes the option to change the watched status to unwatched and vice versa. I cannot locate that option on the Velo V. (The long press on file name hides watched files) Is there currently a way to change the watched/unwatched flag?
If you long-press the play button it will toggle the watched status of the currently highlighted item (including seasons or entire series if that is what is highlighted). The only exception to this is with widgets on the home screen but that is a Kodi limitation. The shortcut you’re mentioning on your Android device, long-press OK/select/enter is not present with the OSMC remote because there is a dedicated menu button (the three lines) which, with a short press, will bring up the context menu (the one at question) and with a long-press will bring up the side/slide-out menu.
Thank you very much. I did look through various things before posing the question and I’m somewhat embarrassed because the answer is right there. My only defence is newbie status with the Vero. I appreciate your help.
