I own a Vero 4k+ connected directly to a Panasonic GZ960 TV, when I’m on home screen of vero, and change from Vero 4k+ to TV, the Vero goes to weather screen, how can I avoid that?
I have the CEC enabled on Vero 4k+ going into stand by state when I shutdown my TV, and I’m using an Harmony 650 controller (with Vero 4k+ profile).
I supose that it’s because a CEC command, Is it possible to disable the weather screen in vero, for avoid going into it when I change to TV? (I don’t need this screen for nothing). I’m using OSMC skin (don’t know if it’s important).
Provide debug enabled logs and reproduce the issue then we might know what causes it.
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
The log show F9 and being received and issuing the command to open weather. I find this rather confusing as the only thing F9 is mapped to by default is volume down. What exactly is in your ~/.kodi/userdata/keymaps/gen.xml file? If there is not something in there that is mapping the weather screen then the only thing I can think of is editing gen.xml to contain the following and rebooting to let it take effect…
