Hello,
I’m trying to install OSMC into my AppleTV1.
I have downloaded the Windows installation program and succefully created the bootable USB key.
Then I have power on my AppleTV with the usb and it seems the installation has gone to the end correctly.
But when I reboot the AppleTV the screen I get is the following.
What does it means?
Thanks.
Could be a variety of things
To get a better understanding of the problem you are experiencing we need more information from you. Please see How to submit a useful support request - General - OSMC for advice on how to help us.
toibs
3
Mine did that initally. Different memory stick, or try low level formatting the usb anfd then installing again…
Ok Thanks. I’ll try with different keys…
