I’ve been searching for two days for some idea of whether this is even a problem to be solved. Before the Aug upgrade I was getting about 10-12 on my rpi2 with most streaming media oin kodi. I had a modest oc to 1ghz and had tried a wide variety of settings including an advancedsettings.xml. what the settings were isn’t so important since they didn’t make any difference. After the update to Isengard I’m getting under 7 fps.
I’m using Big Buck Bunny as my source, though it doesn’t seem to matter. Even media on a usb drive gave the same playback. I have not purchased the mpeg2 or vx-1 codecs though i’m not playing anything that requires them.
I thought perhaps I had made some changes that caused this so I reloaded osmc and booted fresh. No change.
Perhaps this is normal for the pi. I have a cheap m8s box which has a frustratingly laggy GUI (far outperformed by the pi 2) but it can render the same video at about 24 fps and it looks noticeably better (it’s still running Helix, haven’t figured how to update that one yet). It hasn’t mattered whether they have been connected via Ethernet cable or wifi.
I’d like to think there is something I can do because the pi 2 is reputed to be much better than this box. I’m beginning to wonder…
Here’s hoping…
