When plaing vídeo the main menu is always popping up. When turning on, i get a message that pulse eight cec adapte not detected.
To get a better understanding of the problem you are experiencing we need more information from you. Please see How to submit a useful support request - General - OSMC for advice on how to help us.
If TV is not CEC capable then disable CEC in system/input/peripherals/CEC settings to avoid the CEC messages.
Can you give a clue when the menu popped up in log?
e.g. did you press a unique key just before or just after, or do you the time it occurred?
Hello and thank you.
I am analizyng the log. O dont understand much.
O thank vídeo starts here:
13:41:05 101.141716 T:2850026528 DEBUG: CSMBFile::Open - opened Marco_Particular/Barbie.e.as.Tres.Mosqueteiras.2009.PORTUGUESE.DVDRip.XviD-NoGrp/Barbie.e.as.Tres.Mosqueteiras.avi, fd=10000
About 20 seconds after the menu pops and then i press a key.
Which key? Can you indicate an approximate time in the log when the menu appeared?
If not, capture another log, and when you see the menu pop up press a unique key, or stop the file.
Then I’ll have something to look for.
