Hi guys, anyone has an idea how i can Connect to a wifi with username and password authefication?
Connman dont let me connevt to the wifi cause the password is not enough Parameter for my wifi.
You could try using the command line tool connmanctl - this has been reported to work for one user using WPA2 Enterprise, but is not supported by us and has not been tested by us.
I have the same problem. Did it work?
