Hey everyone,
I hope that someone here can help me with my little wifi problem. Here’s what happened:
I had my wifi perfectly setup and running. When browsing through the “my osmc” network settings, I highlighted the “enable wifi adapter” setting and accidentally pressed some button which would then immediately disable wifi. So now I have no way to enable it again because I cannot connect to the rpi anymore.
I have no way to connect the rpi via cable as I share the wifi with my neighbors and the router is in their house. I do not have a USB keyboard.
Is there any way to edit the “my osmc” network settings on the sd card in a conf file or something? I think this would do the job for me.
P.S.: To prevent this from happening, it would be a good idea to implement a confirm button or something when en/disabling a network adapter.
