Wifi settings not sticking
I managed to run Ethernet to my NAS and use a wireless USB (Edimax EW-7822UAC) for internet.
Everything works fine, except the wireless is not engaged on reboot.
I need to go into My OSMC every time I reboot and select the network to connect to.
The network settings and password are saved so I don’t have to enter the password each time, but it’s like there is no “automatically connect” function. Unless that is what the “wait for network” option does?
Also, it’s a bit trick to ensure the settings have stuck. I have noticed that after entering the password for a network and after an IP address is obtained, I have to move to another menu (say, wired) in order to ‘refresh’ the wireless tab. I then see the Apply button and need to click that in order to get an internet connection up and running. Although that only applies until the next reboot, as indicated above.
Are you on the latest version?
Yes - the 18 January 2016 image…
