Hello,
I try to use a ESP8089 to connect a RPi Zero to my wifi using these instructions.
As OSMC does not use the original Raspbian kernel …
sudo apt-get -y install dkms raspberrypi-kernel-headers
… does not work.
Instead I used:
sudo apt-get -y install dkms rbp1-source-4.4.27-6-osmc
sudo apt-get -y install dkms rbp1-headers-4.4.27-6-osmc
Nevertheless I have no luck:
osmc@osmc:~$ sudo dpkg -i esp8089-dkms_1.9.20160526_all.deb
Selecting previously unselected package esp8089-dkms.
(Reading database ... 38576 files and directories currently installed.)
Preparing to unpack esp8089-dkms_1.9.20160526_all.deb ...
Unpacking esp8089-dkms (1.9.20160526) ...
Setting up esp8089-dkms (1.9.20160526) ...
Loading new esp8089-1.9.20160526 DKMS files...
First Installation: checking all kernels...
Building only for 4.4.27-6-osmc
Building for architecture armhf
Module build for the currently running kernel was skipped since the
kernel source for this kernel does not seem to be installed.
Any ideas?
