Hi, Sam first of all thanks for al your hard work!
i installed osmc alpha 4 on my new raspberry pi 2 and it runs great!
But i have a couple of questions.
Where do i have to copy my advancedsetting.xml?
is it in /usr/share/kodi/userdata.
And how to install oscam and tvheadend?
i have a sundtek media tv pro dvb-c usb stick is this supported in osmc?
Thanks!
Not sure on your other points, but you should copy your advancedsettings.xml file to:
/home/osmc/.kodi/userdata/
hi i have the same problem, i do not found the file “advancedsetting” in /home/osmc/.kodi/userdata/ or /usr/share/kodi/userdata…
But i found this file in “/usr/share/kodi/system” my question is This is the file that is modified or have to create another?.
(Winscp not allow me to modify this file)
please help. thanks
