Hi There, I just installed the last release of osmc on raspberry PI.
I tried to connect the device to 3 secure network but all of them had failed the auth, it workoks only if I remove the security auth.
Doesn’t matter Which level of security i set (wep,wpa)
Any idea?
Here the logs date today time 21:32
Jan 09 21:31:24 osmc mediacenter[400]: enabled
Jan 09 21:31:27 osmc wpa_supplicant[306]: wlan0: Failed to initiate sched scan
Jan 09 21:31:27 osmc mediacenter[400]: enabled
Jan 09 21:31:30 osmc wpa_supplicant[306]: wlan0: Failed to initiate sched scan
Jan 09 21:31:33 osmc wpa_supplicant[306]: wlan0: Failed to initiate sched scan
Jan 09 21:31:36 osmc wpa_supplicant[306]: wlan0: Failed to initiate sched scan
Jan 09 21:31:39 osmc wpa_supplicant[306]: wlan0: Failed to initiate sched scan
Jan 09 21:31:43 osmc wpa_supplicant[306]: wlan0: Failed to initiate sched scan
Jan 09 21:31:45 osmc wpa_supplicant[306]: wlan0: Failed to initiate sched scan
Jan 09 21:31:49 osmc wpa_supplicant[306]: wlan0: Failed to initiate sched scan
Jan 09 21:31:51 osmc wpa_supplicant[306]: wlan0: Failed to initiate sched scan
Jan 09 21:31:55 osmc connmand[207]: Skipping disconnect of 4655434b574542_managed_psk, network is connecting.
Jan 09 21:31:55 osmc connmand[207]: ipconfig state 2 ipconfig method 1
Jan 09 21:31:55 osmc wpa_supplicant[306]: wlan0: Trying to associate with 9c:97:26:41:a1:37 (SSID=‘FUCKWEB’ freq=2437 MHz)
Jan 09 21:31:55 osmc connmand[207]: wlan0 {RX} 2398 packets 669354 bytes
Jan 09 21:31:55 osmc connmand[207]: wlan0 {TX} 23 packets 8309 bytes
Jan 09 21:31:55 osmc connmand[207]: wlan0 {update} flags 102403 <UP,LOWER_UP>
Jan 09 21:31:55 osmc connmand[207]: wlan0 {newlink} index 3 address B8:27:EB:01:41:FE mtu 1500
Jan 09 21:31:55 osmc connmand[207]: wlan0 {newlink} index 3 operstate 5
Jan 09 21:31:55 osmc wpa_supplicant[306]: wlan0: Associated with 9c:97:26:41:a1:37
Jan 09 21:31:59 osmc connmand[207]: wlan0 {RX} 2412 packets 671018 bytes
Jan 09 21:31:59 osmc wpa_supplicant[306]: wlan0: CTRL-EVENT-DISCONNECTED bssid=9c:97:26:41:a1:37 reason=0 locally_generated=1
Jan 09 21:31:59 osmc connmand[207]: wlan0 {TX} 29 packets 9401 bytes
Jan 09 21:31:59 osmc wpa_supplicant[306]: wlan0: WPA: 4-Way Handshake failed - pre-shared key may be incorrect
Jan 09 21:31:59 osmc wpa_supplicant[306]: wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=1 ssid=“FUCKWEB” auth_failures=1 duration=10 reason=WRONG_KEY
Jan 09 21:31:59 osmc connmand[207]: wlan0 {update} flags 36867
Jan 09 21:31:59 osmc connmand[207]: wlan0 {newlink} index 3 address B8:27:EB:01:41:FE mtu 1500
Jan 09 21:31:59 osmc connmand[207]: wlan0 {newlink} index 3 operstate 2
Jan 09 21:31:59 osmc connmand[207]: ipconfig state 7 ipconfig method 1
Jan 09 21:32:01 osmc wpa_supplicant[306]: wlan0: Failed to initiate sched scan
Jan 09 21:32:04 osmc wpa_supplicant[306]: wlan0: Failed to initiate sched scan
Jan 09 21:32:05 osmc sudo[779]: osmc : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/mv /var/tmp/config.txt /boot/config.txt
Jan 09 21:32:05 osmc sudo[779]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jan 09 21:32:05 osmc mediacenter[400]: mv: failed to preserve ownership for ‘/boot/config.txt’: Operation not permitted
Jan 09 21:32:05 osmc sudo[779]: pam_unix(sudo:session): session closed for user root
Jan 09 21:32:13 osmc wpa_supplicant[306]: wlan0: Failed to initiate sched scan
Jan 09 21:32:21 osmc mediacenter[400]: grep: /var/log/apt/term.log: No such file or directory
Jan 09 21:32:21 osmc mediacenter[400]: grep: /var/log/apt/history.log: No such file or directory
Jan 09 21:32:21 osmc sudo[803]: osmc : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/journalctl
Jan 09 21:32:21 osmc sudo[803]: pam_unix(sudo:session): session opened for user root by (uid=0)
I have also posted this in a different section of the forim exact same issue you are describing.
The only way I could get the Pi3 (on 2.4GZ.) to be seen by the router is to set the router to a open network. This is indicate to me that the network card on the pie is working.
Check if you can connect if you set your network to open network without any encryption.
Can you also check in My OSMC and then go to network and look under Wireless what shows up.
On the wireless page under enable adapter there should be something there that says Configure Network Manually. For some reason I do not have that option. Let me know if you have that or not.
PS. I am running version 16.1
