Hi all,
I’m running a Pi +B with OSMC on the latest build. I bought this wireless antenna from the Pi store https://thepihut.com/products/usb-wifi-module-with-antenna-for-raspberry-pi. I would assume that it’s compatible?
In the Wireless settings, the networks are being picked up by the Pi and Antenna, however when I try connecting to them, I just get the loading spinner. I can’t exit the connection attempt so I’m having to remove the power from the device to kill it.
It works fine over an Ethernet connection.
Many thanks,
Ryan
