I’m having no luck. I get “Failed to pair: org.bluez.Error.AuthenticationCanceled”
I try again, and I get "Failed to pair: org.bluez.error.AlreadyExists
Check with devices
the device list. Then remove the paired device remove <MAC>
and then try from start.
If still not working copy/paste your console output here.
I use a Logitech K480 when I need to do a lot of keyboard work with my Vero. It’s also not small, but it can be paired with 3 home theater devices at the same time, so it saves room that way.
I got it this time. Hopefully it will still remember the connection if I don’t press a key for 3 minutes! I very much appreciate your patient help–I’ll be back if trouble persists. Thanks again.
That’s cool. I don’t know if mine can pair with other devices at the same time, but that would be handy. I’m just happy to have it working solidly on the Vero, thanks to fzinken.
