Wlan connection only!
Hi all,
I am completely new to this, i bought my raspberry pi 3 just before christmas and haven’t used it for anything yet!
right, I’ve downloaded Noobs from the Raspberry Pi site.
I’ve transferred Noobs onto my memory card.
Started up the Raspberry Pi with memory card, managed to get an internet connection, found OSMC and installed. Seemed like no problems to this point…
I’ve then gone through the OSMC setup, time zone etc, and when it gets to network it can’t find a network. So I finish the setup, and then gone to network settings.
My router is on the list, password in, CONNECTED. But there is no internet connection, just a connection to my router.
Am i being really stupid, is there something i need to change on my router to allow this to connect? Its a SKY router.
I really look forward to hearing from somebody with some help, as i have no idea what I’m doing and no idea what to search for online to resolve it. and its doing my head in!!!
thanks in advance
Spencer (absolute NOOB)
What is indicating to you that you have no internet connection? Because this could possibly be reported wrong in the Kodi System Info screen if that is the location you are referring to.
Hi thanks for the reply. I’ve tried to visit a link in file manager and a screen comes up saying that I don’t have an internet connection. Although my network settings say it’s connected to my network
You need to SSH into the pi and ping a known good address such as google. You need a second confirmation other than your “link in file manager.”
https://osmc.tv/wiki/general/accessing-the-command-line/
ok, i think I’ve done that correctly. and this was the result…
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Updating APT cache. Please be patient.
Generating locales (this might take a while)…
en_GB.UTF-8… done
Generation complete.
osmc@osmcspud:~$ ping google.com
PING google.com (216.58.208.142): 56 data bytes
64 bytes from 216.58.208.142: seq=0 ttl=57 time=14.516 ms
64 bytes from 216.58.208.142: seq=1 ttl=57 time=15.713 ms
64 bytes from 216.58.208.142: seq=2 ttl=57 time=21.949 ms
64 bytes from 216.58.208.142: seq=3 ttl=57 time=19.343 ms
64 bytes from 216.58.208.142: seq=4 ttl=57 time=21.398 ms
64 bytes from 216.58.208.142: seq=5 ttl=57 time=19.712 ms
64 bytes from 216.58.208.142: seq=6 ttl=57 time=117.506 ms
64 bytes from 216.58.208.142: seq=7 ttl=57 time=15.173 ms
64 bytes from 216.58.208.142: seq=8 ttl=57 time=22.615 ms
64 bytes from 216.58.208.142: seq=9 ttl=57 time=22.513 ms
64 bytes from 216.58.208.142: seq=10 ttl=57 time=22.523 ms
64 bytes from 216.58.208.142: seq=11 ttl=57 time=20.157 ms
64 bytes from 216.58.208.142: seq=12 ttl=57 time=22.128 ms
64 bytes from 216.58.208.142: seq=13 ttl=57 time=21.148 ms
64 bytes from 216.58.208.142: seq=14 ttl=57 time=19.054 ms
64 bytes from 216.58.208.142: seq=15 ttl=57 time=20.565 ms
64 bytes from 216.58.208.142: seq=16 ttl=57 time=35.022 ms
64 bytes from 216.58.208.142: seq=17 ttl=57 time=17.682 ms
64 bytes from 216.58.208.142: seq=18 ttl=57 time=116.955 ms
st64 bytes from 216.58.208.142: seq=19 ttl=57 time=16.359 ms
op
64 bytes from 216.58.208.142: seq=20 ttl=57 time=26.222 ms
64 bytes from 216.58.208.142: seq=21 ttl=57 time=17.931 ms
stop
64 bytes from 216.58.208.142: seq=22 ttl=57 time=16.729 ms
64 bytes from 216.58.208.142: seq=23 ttl=57 time=15.846 ms
64 bytes from 216.58.208.142: seq=24 ttl=57 time=61.416 ms
64 bytes from 216.58.208.142: seq=25 ttl=57 time=17.366 ms
64 bytes from 216.58.208.142: seq=26 ttl=57 time=32.319 ms
64 bytes from 216.58.208.142: seq=27 ttl=57 time=16.199 ms
64 bytes from 216.58.208.142: seq=28 ttl=57 time=16.798 ms
64 bytes from 216.58.208.142: seq=29 ttl=57 time=16.995 ms
64 bytes from 216.58.208.142: seq=30 ttl=57 time=34.650 ms
64 bytes from 216.58.208.142: seq=31 ttl=57 time=16.603 ms
64 bytes from 216.58.208.142: seq=32 ttl=57 time=16.757 ms
64 bytes from 216.58.208.142: seq=33 ttl=57 time=16.707 ms
64 bytes from 216.58.208.142: seq=34 ttl=57 time=17.260 ms
64 bytes from 216.58.208.142: seq=35 ttl=57 time=15.737 ms
64 bytes from 216.58.208.142: seq=36 ttl=57 time=33.574 ms
^C
google.com ping statistics —
37 packets transmitted, 37 packets received, 0% packet loss
round-trip min/avg/max = 14.516/26.787/117.506 ms
osmc@osmcspud:~$
This indicates that the internet connection is fine, the problem is with your “link in file manager.”
ha, ok. thanks very much for your help. i think I’ve done the ‘ping’ correctly?
i followed the steps in the link you sent me, then typed ‘ping google.com
You’ve done the ping perfectly!
Next time though place any long terminal output / logs / media info on paste bin:
http://paste.osmc.io/
It looks like you have a network connection with Internet access.
Remember that Kodi isn’t a reliable indicator of whether you have an Internet connection.
