The device is Vero 4K, and I use Xbox one media remote find that sound volume key isn’t work.
So can I fix it? How to do it? Thank you
Did you configure an LIRC keymap via My OSMC -> Remotes?
I don’t know a lot about this remote, but you may need to stop Kodi and use irrecord to create your own key mapping.
I find key editor addon maybe it can solve it.
Thanks Sam~ I will be check again
