I haven’t used OSMC before.
I installed OSMC on a raspberry pi 2.
I tried to add a music add-on, I tried grooveshark and mpd.
When I select to run the addon it says “Script Failed”.
The error in the kodi log was “XML File for Window is missing”. I had a look at the mpd error in more detail.
The line failing is:
selectorUI = SelectMPDProfile( ‘select-profile.xml’,addon.getAddonInfo(‘path’), skin)
I am presuming that one of the xml files doesn’t exist or a path is incorrect.
The addon path is “/home/osmc/.kodi/addons/script.mpdc”
osmc@osmc:~$ ls /home/osmc/.kodi/addons/script.mpdc
addon.xml changelog.txt default.py default.py~ default.pyo fanart.jpg icon.png LICENSE.txt README resources
It is using the skin Confluence and I found that there is a file /home/osmc/.kodi/addons/script.mpdc/resources/skins/Confluence/720p/select-profile.xml
I could attempt to debug this further with my weak python skills, but perhaps someone can point me in the right direction? This is just a clean install of OSMC so I’m not sure how anything can be configured incorrectly but I haven’t used it before and I didn’t find a post with the same issue so I’m not sure.
Thanks in advance
The full kodi log contains:
20:16:40 T:1793405984 ERROR: EXCEPTION: XML File for Window is missing
20:16:40 T:1793405984 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<–
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type ‘exceptions.RuntimeError’>
Error Contents: XML File for Window is missing
File “/home/osmc/.kodi/addons/script.mpdc/default.py”, line 148, in
RuntimeError: XML File for Window is missing
–>End of Python script error report<–
