Does anyone know if xperience1080 skin still crashes the most recent update (early April) ? I really don’t want to swap skin and have the whole thing crash again.
is Xperience 1080 compatible with Jarvis ?
Don’t think so. A lot of people reported problems.
A forumsearch will help.
Well actually if you are so interested you could have tested yourself. Just if the sad face happen edit guisettings.xml and change this line to point to osmc skin <skin default="true">skin.osmc</skin>
nano .kodi/userdata/guisettings.xml
But I have just tested it for you, no change currently.
