Hi my osmc was locked up when I switched on the TV this evening so after much trying to wake it up I had to pull the plug
On restarting when I tried to run the YouTube addon it prompted me to re-verify through Connexion : comptes Google Unfortunately this doesn’t work and throws up an error. I’ve placed the log at,
http://paste.osmc.io/ikumawefak
I can see the problem as its clearly in the log as an error but have no idea how to resolve. I’ve already removed and reinstalled the plugin but the same error occurs each time. I’ve also updated osmc to the latest rev, again with no luck.
I assume some fundamental file is corrupt and I may be looking at a fresh install…ho hum
FYI - OSMC locked up while sitting idle in the music section.
Also FYI - other addons that rely on the youtube addon still work…go figure!
