Announcing end of support for Vero 4K and 4K+ - OSMC
There’s no requirement to use Bookworm to run Docker Aarch64 containers.
I demonstrated how to run Aarch64 containers some time ago.
Even if you upgrade from Bullseye to Bookworm you will still be running an armhf userland, so this won’t change anything there. You can still run aarch64 container on either platform regardless
You are more likely to get support on Bullseye than Bookworm.
Hope this helps
Stings a bit since I bought mine just weeks before the V came out :slightly_frowning_face:
Can’t see how that could be the case. We stopped selling Vero 4K + a long time before we introduced the V.
April 2023, I don’t remember when the V came out, maybe my imagination then.
Still it’s, less than 2 years old.
Sam, my last order for Vero 4K+ was for two units. Will I receive double the £ upgrade discount if I upgrade both at the same time please?
You need to contact sales@osmc.tv for that
Hi Sam. Practical question: does the Vero 5 ship from the UK exclusively? I’d be happy to upgrade but wondering whether I’ll have to steel myself for extra taxes and fees, etc. into the EU.
How long will the discount be available?
I also had 2 Vero 4k+s.
Yes. We have an EU reseller but you won’t be able to get the upgrade price through them.
I don’t have a firm date on ending the offer, but it won’t last forever. If you want to purchase two Vero V in one order, just send an email to sales@osmc.tv and we will sort it out.
Understood, thank you!
You’re not the only one. I bought my Vero 4K+ in December 2022 so I’ve only had two years of updates. I appreciate Sam wants to move on but that’s a long way from the five years of updates promised for those who, like me, purchased the device later on.
Understood. The five years were promised from the date of release, not from the date you purchased the product. This ended up as seven years for the 4K + and almost nine years for the 4K.
I will look at ways to make that clearer on the website.
We have also worked on upstreaming support for the Vero 4K and 4K + so that it lives on indefinitely, albeit not necessarily via OSMC. It has been supported by upstream / mainline Linux kernels for some time.
Hi @sam_nazarko ,
thanks for all the hard work. My device is still working quite well, so I’d hate it to see it unused because of discontinued support. Personally I have no problem with running old Kodi version, but my box is running SSH facing public internet and Samba on local network. I’m guessing all updates will be discontinued? The message on login shell feels like running apt to fetch new packages is a very bad idea:
Notice: This device is no longer officially supported as of 31/01/2025.
As a result, you will no longer receive officialy supported updates on this device.
You may wish to exercise caution using apt to perform upgrades.
For more information: please see https://osmc.news/QTupI
If no new security updates will be applied I guess, running SSH on public internet is no longer viable.
You can keep updating via the APT repositories, but we don’t officially support them anymore. I hope that makes things clearer
So I if pull new packages I’ll only get new packages from Debian (because OSMC is based on it), but this will not be supported by you. So if something breaks, it’s on me and help from forum right?
Yes.
@sam_nazarko Just chiming in to say “thank you!”, the 4K has been brilliant, and I’m looking forward to see how far we can reach with the V :slight_smile:
Onwards and upwards!
Cheers!
Is there any way of disabling the message that is shown when logging in via SSH?
If I’m logged in via SSH and want to edit something in /etc, I’d used to be able to type /e{tab}, but now I have to type /et{tab} due to the end_of_life_message file in /.
