How can i exit out of the journalctl?
CTRL+X doesnt work.
Shawn
CTRL+X doesnt work.
Shawn
Q i think it was
Q or CTRL-C works.
Alternatively, you can run systemctl status mediacenter
Agreed. Regular reboots is a function of Windows, not Linux
Seems that everything works fine, but…
One problem is still alive. Everyday i restart the mediacenter at 5 o clock and my TV turns on at this time HDMI CEC is probably the problem.
Where can i turn off the HDMI CEC Function so that the TV dont turns on by itself?
Or is there a way to ignore the HDMI CEC function while executing the command?
Many Thanks
Maybe, if you play with this file: /home/osmc/.kodi/userdata/peripheral_data/cec_CEC_Adapter.xml
Content:
<settings>
<setting id="activate_source" value="1" />
<setting id="button_release_delay_ms" value="0" />
<setting id="button_repeat_rate_ms" value="0" />
<setting id="cec_hdmi_port" value="1" />
<setting id="cec_standby_screensaver" value="0" />
<setting id="cec_wake_screensaver" value="0" />
<setting id="connected_device" value="36037" />
<setting id="device_name" value="Kodi" />
<setting id="device_type" value="1" />
<setting id="double_tap_timeout_ms" value="300" />
<setting id="enabled" value="1" />
<setting id="pause_or_stop_playback_on_deactivate" value="231" />
<setting id="pause_playback_on_deactivate" value="0" />
<setting id="physical_address" value="0" />
<setting id="power_avr_on_as" value="0" />
<setting id="send_inactive_source" value="0" />
<setting id="standby_devices" value="231" />
<setting id="standby_devices_advanced" value="" />
<setting id="standby_pc_on_tv_standby" value="36028" />
<setting id="standby_tv_on_pc_standby" value="0" />
<setting id="tv_vendor" value="0" />
<setting id="use_tv_menu_language" value="0" />
<setting id="wake_devices" value="36037" />
<setting id="wake_devices_advanced" value="" />
</settings>
Of course, do make a backup of this file before tweaking any option. Your choice for any feature is either 0
or 1
Alternatively, in Kodi: Settings → System → Input → Peripherals → CEC Adapter
Under CEC Adapter, you’ll see many options. The first one or the third one will probably help you.
In fact, I think this method (via Kodi) is better to fix your problem.
The Kodi wiki for CEC: https://kodi.wiki/view/CEC
Also, I happened to discover by accident this thread (just in case): Ignoring CEC settings
(I’m not able to test for the moment)
