Try this: https://collab.osmc.tv/s/T8BGEcIn9qJee4M
Cheers Graham, plays perfectly, switches my TV to HDR mode and the colours look really good.
So Iâm fully confident my TV has no issues with HLG content.
Shame I cant try the other one, ive always been partial to a bit of cinematic jazz!
The title says HDR10. Doesnât seem to be HLG??
Yeah that one doesnât make my telly go into HDR mode at all unfortunatelyâŚthe one you posted worked fine.
Weird because my TV definitely supports HDR10 as well.
Cheers, it works perfectly.
Try the âView all Wimbledonâ option in your TVâs iplayer app.
The UHD stream is towards the bottom of the list
Yeah thatâs how I found it in the iPlayer app on the Firestick 4k, the UHD Center Court stream is playing perfectly with HLG in that.
In my TVs app there is no such UHD stream available thoughâŚnot overly concerned though, just a bit of a PITA to have to move the Firestick from my bedroom to the lounge. First world problems.
There is something a bit odd thoughâŚif I let the Firestick auto select the refresh rate, it switched to 60Hz, which ties in with what @Steve_Neal posted about the manifest.
But it doesnât look right, like youâre watching 50fps content at 60Hz refresh rate.
Ive manually set the Firestick to display everything at 50Hz, and it looks perfect.
When played through the Kodi iPlayer add-on, its detected as 50fps, and displayed as suchâŚand it plays fine (apart from no HDR)
My conclusion is the stream is actually 2160p50âŚnot 2160p60.
Live-broadcast BBC material will always be captured at 50Hz.
Yep, what threw me was I didnât realise the iPlayer app on the fire stick doesnât switch the frame rate automaticallyâŚso it just sits at 60Hz unless you manually override it in the settings.
I think maybe it was a typo from @Steve_Neal
Typo in my original post about Wimbledon - I did, of course, mean 2160p50 and have edited the original post.
All UK origination will be i25, p25 or p50 - and streaming is likely to be p25 or p50.
Sport and entertainment is shot 1080i25 or 2160p50 native - both have 50Hz motion - whilst most non-soap drama (plus Hollyoaks, Casualty and Holby City), high-end factual etc. will be shot p25.
iPlayer HD SDR is pretty much entirely 720p50 Rec 709at 5Mbs h.264/AVC - but the BBCâs Live UHD streams are all p50 h.265/HEVC Rec 2020 HLG (at up to 36Mbs) The recorded natural history stuff was p25.
Very few Amazon apps seem to switch frame rates other than Amazon Prime Video and Kodi/MrMC. Netflix, iPlayer etc. are all running at fixed frame rates.
Yeah Ive noticed that and find it odd.
It cant be that hard to implement so im guessing thereâs some other reason behind it.
I think itâs just a case of people not upgrading their apps that quickly, or developers not specialising that heavily in Amazon Fire TV development?
Android TV also supports a frame rate changing API - but very few Android TV apps properly frame rate switch either. On the other hand, lots of Apple TV tvOS apps upgraded to support their frame rate API pretty quickly. (Though I think iPlayer runs at system frame rate - which is why my Apple TV is set for 50Hz output as default)
Yeah thatâs why I find it strange.
I can understand why companies like Amazon, who provide both hardware and content, would want their content to look better on their own hardware than anyone elsesâŚyet companies like Netflix and the Beeb, who have no dog in the hardware fight, seem a bit slow in updating their apps to implement it.
Youâd think theyâd want their content looking as good as it possibly can.
I recently had a Fire stick for a whole two days before it was sent back to Amazon. Even with the so-called frame-rate matching feature enabled, it was just hopeless. It would occasionally swith to 24p for a film via the Amazon Prime app, but often get stuck and not switch back. And as others have noted, no frame-rate switching at all for iPlayer or Netflix. The whole impression was that itâs a very flaky product.
I took a punt on an Apple 4k TV box instead, and itâs superb. Everything has perfect frame-rate switching, including iPlayer and Netflix. First device Iâve used that does HD at 24p for relevant Netflix titles. Much better than the Fire stick and the PS4.
Its a shame after Wimbledon finishes on Sunday there wonât be any BBC UHD content available for the foreseeableâŚdoes anyone know if they have any more trials/plans in the pipeline?
Thereâs usually a test stream of Planet Earth II in the Beta section of the app. And given that Tokyo 2020 is likely to be 8K/120 I wouldnât bet against a 4K/50 or 4K/60 Olympic stream. And there is the European Cup football next year too.
There are a LOT of platforms and finite amounts of licence-fee funded developer supportâŚ
