Nice! Do long presses work?
Not on my particular remote.
I think that sort of thing is usually a feature of the remote hardware itself (where the remote firmware sends a different IR code for a long-press) I recall years ago having a remote which had a JP1 extender available for it which could do it (would show up in remote master as the X-Shift pseudo buttons), but my remote does not have that (mine has only regular, and “shift” available)
If your remote hardware can handle long press, then it should just be a matter or programming the IR functions to those pseudo button in RemoteMaster.
If this is some kodi side thing (where it detects, and treats “repeats” as a “long-press”, then you’d just need to experiment.)
come to think of it, I scanned in a new lirc.conf on one of my veros , which has some slightly different timing settings.
# Please take the time to finish this file as described in
# https://sourceforge.net/p/lirc-remotes/wiki/Checklist/
# and make it available to others by sending it to
# <lirc@bartelmus.de>
# This config file was automatically generated
# using lirc-0.9.4c(default) on Mon Sep 21 16:56:40 2020
# Command line used: -H default -d /dev/lirc0
# Kernel version (uname -r): 4.9.113-22-osmc
# Remote name (as of config file): int2
# Brand of remote device, the thing you hold in your hand:
# Remote device model nr:
# Remote device info url:
# Does remote device has a bundled capture device e. g., a
# usb dongle? :
# For bundled USB devices: usb vendor id, product id
# and device string (use dmesg or lsusb):
# Type of device controlled
# (TV, VCR, Audio, DVD, Satellite, Cable, HTPC, ...) :
# Device(s) controlled by this remote:
begin remote
name int2
bits 13
flags RC5|CONST_LENGTH
eps 30
aeps 100
one 930 824
zero 930 824
plead 982
gap 112888
toggle_bit_mask 0x800
frequency 38000
begin codes
KEY_0 0x1780
KEY_1 0x1781
KEY_2 0x1782
KEY_3 0x1783
KEY_4 0x1784
KEY_5 0x1785
KEY_6 0x1786
KEY_7 0x1787
KEY_8 0x1788
KEY_9 0x1789
KEY_HOME 0x178D
KEY_INFO 0x17BA
KEY_MENU 0x179B
KEY_BACK 0x179F
KEY_UP 0x1794
KEY_DOWN 0x1795
KEY_LEFT 0x1796
KEY_RIGHT 0x1797
KEY_OK 0x17A5
# ## Want to use amplifier for volume control instead of Vero
# #KEY_VOLUMEUP 0x1790
# #KEY_VOLUMEDOWN 0x1791
# #KEY_MUTE 0x178F
KEY_ZOOM 0x178C #display button on remote
KEY_SUBTITLE 0x1799
KEY_LANGUAGE 0x179A
KEY_TEXT 0x1798 #TTX/Mix
KEY_TITLE 0x179C
KEY_STOP 0x17B6
KEY_PLAY 0x17B5
KEY_PAUSE 0x17B0
KEY_RECORD 0x17B7
KEY_REWIND 0x17B2
KEY_FASTFORWARD 0x17B4
KEY_PREVIOUS 0x179E
KEY_NEXT 0x17A4
KEY_RED 0x178B
KEY_GREEN 0x17AE
KEY_YELLOW 0x17B8
KEY_BLUE 0x17A9
KEY_CHANNELUP 0x17A0
KEY_CHANNELDOWN 0x17A1
end codes
end remote
Also note, I’m running on the the 4.9 kernel branch, and this capture was when running the 4.9 kernel. (that may-or-may-not make a difference)
One a slightly different JP1 related note:
If you find a different protocol working better (which is entirely possible, I originally programmed using the Samsung TV device protocol, which was great until I bought a Samsung TV which then was in conflict).
The method is simple, start with the protocol of your choice (where you have a matching lirc.conf already that seems to work, even if it is missing most of the buttons you want to use), and then for each additional button you want to add, just add a new function and hex code in remote master (and assign it to a button), and add a matching lirc.conf code (using the toggle-bit-mask to covert from the JP1 hex code to the lirc one)
Or, you can start with any-old JP1 device file in Remote master, (and add whatever addtional functions you think you need with new hex codes) and then run irrecord to capture everything to a new lirc.conf
