Hi Larry,
These should be a good start:
http://www.tomshardware.co.uk/faq/id-3114787/open-firewall-ports-windows.html
Thanks Tom.
Hi Larry,
Thanks Tom.
Hi Larry,
Apologies, we must have posted our last posts about the same time and I missed yours.
I’ve had a look it would be probably easier just to add my osmc to programs, as there doesn’t appear to be away to change the shortcuts for the system menu on the user interface.
https://seo-michael.co.uk/how-to-create-add-on-shortcuts-to-home-screen-on-xbmc/
This guides a bit out of date, so ignore.
Open Kodi
Select SYSTEM
Select Appearance
Select Skin > Settings
Select Add-On Shortcuts
Its
System
Settings
Interface
- Configure skin …
Then follow the rest of the guide.
To add shortcuts to the program menu, you need to scroll down to the bottom.
I’m going to mark this topic as solved as you have resolved your initial issue, so your solution will show at the top of the topic. Feel free to post in this topic again, if you have issues with the shortcut (or raise a new topic.)
Thanks Tom.
