There’s no guarantee it’ll run at the right time, but we’ll know once you reboot.
new log after rebooting with rc.local modified: https://paste.osmc.tv/ehuyeroqux
Unfortunately, rc.local runs too late.
Therefore please unplug the device, plug it back in and run grab-logs -J (big J).
And I have followed your instruction:
- Unplugging device.
- run:
sudo modprobe r8152
echo “2357 0601” | sudo tee /sys/bus/usb/drivers/r8152/new_id - plug it back
log after this: https://paste.osmc.tv/gemocomavu
osmc@osmc : ~ $ grab-logs -J
Logs successfully uploaded.
Logs available at https://paste.osmc.tv/eziqeyivug
osmc@osmc : ~ $
Should I reflash with May update firmware image? It was working perfectly.
It’s still picking up cdc_ether.
Perhaps @sam_nazarko can say whether blacklisting cdc_ether will cause any undesirable side effects.
So I am doomed ![]()
Probably. It might be better if he can produce a new kernel, though officially I think he’s still on holiday.
I haven’t changed anything with Ethernet in this update
I am installing fresh image from May to see what happens
If would be useful to repeat the iperf3 tests and to see if it picks up cdc_ether.
Done.
It is back to full speed.
osmc@osmc:~$ iperf3 -R -c 192.168.1.4
Connecting to host 192.168.1.4, port 5201
Reverse mode, remote host 192.168.1.4 is sending
[ 4] local 192.168.1.90 port 43397 connected to 192.168.1.4 port 5201
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 19.1 MBytes 160 Mbits/sec
[ 4] 1.00-2.00 sec 33.6 MBytes 282 Mbits/sec
[ 4] 2.00-3.00 sec 31.9 MBytes 267 Mbits/sec
[ 4] 3.00-4.00 sec 34.0 MBytes 285 Mbits/sec
[ 4] 4.00-5.00 sec 34.2 MBytes 287 Mbits/sec
[ 4] 5.00-6.00 sec 27.3 MBytes 229 Mbits/sec
[ 4] 6.00-7.00 sec 34.1 MBytes 286 Mbits/sec
[ 4] 7.00-8.00 sec 26.0 MBytes 218 Mbits/sec
[ 4] 8.00-9.00 sec 30.2 MBytes 253 Mbits/sec
[ 4] 9.00-10.00 sec 25.9 MBytes 217 Mbits/sec
[ ID] Interval Transfer Bandwidth Retr
[ 4] 0.00-10.00 sec 298 MBytes 250 Mbits/sec 6543 sender
[ 4] 0.00-10.00 sec 296 MBytes 248 Mbits/sec receiver
iperf Done.
osmc@osmc:~$
and the log: https://paste.osmc.tv/vijoroyaze
I’ll need to do a bit more investigation. Dobranoc.
ok
Dobranoc ![]()
I have installed June update again and the problem has repeated:
[ 4] local 192.168.1.90 port 40018 connected to 192.168.1.4 port 5201
[ 4] 0.00-1.00 sec 2.58 MBytes 21.7 Mbits/sec
[ 4] 1.00-2.00 sec 1.92 MBytes 16.1 Mbits/sec
[ 4] 2.00-3.00 sec 2.46 MBytes 20.7 Mbits/sec
[ 4] 3.00-4.00 sec 1.19 MBytes 9.97 Mbits/sec
[ 4] 4.00-5.00 sec 3.46 MBytes 29.0 Mbits/sec
[ 4] 5.00-6.00 sec 3.72 MBytes 31.2 Mbits/sec
[ 4] 6.00-7.00 sec 1.72 MBytes 14.4 Mbits/sec
[ 4] 7.00-8.00 sec 1.71 MBytes 14.3 Mbits/sec
[ 4] 8.00-9.00 sec 3.77 MBytes 31.6 Mbits/sec
[ 4] 9.00-10.00 sec 1.87 MBytes 15.7 Mbits/sec
[ 4] 0.00-10.00 sec 26.9 MBytes 22.5 Mbits/sec 4549 sender
[ 4] 0.00-10.00 sec 24.4 MBytes 20.5 Mbits/sec receiver
iperf Done.
osmc@osmc:~$
And a fresh log after the update: https://paste.osmc.tv/enozajifak
There would be no kernel changes responsible for this.
I did merge some IPTables changes in the kernel config – but I’d be surprised if that’s the cause of the problem.
Thanks for this information. I am available to help troubleshoot and solve this problem as a tester.
Do you really need the GB USB adapter? I have lots of 4K HDR and have never had buffering issues with my 4K using the built in connection.
I have had occasionally some buffering and sound issues on 4K HDR content, which really pissed me off (even with nfs fstab enabled) . After installing the adapter it has worked perfectly - zero problems. Faster skipping, general more pleasant user experience.
I have autofs mounted NFS drives and have not had the issue. But I do not normally do skipping.
(autofs and fstab will have the same performance, so that would not make a difference)
It may just be something with how the content was ripped that’s needing more bandwidth. All of my UHD content was ripped by myself and not remuxed in any way.
