18:49:39 1203.746582 T:2652574704 DEBUG: DoWork - took 7306 ms to load special://skin/backgrounds/default_bg.jpg
18:49:39 1203.751465 T:2911187952 DEBUG: CPythonInvoker(14, /home/osmc/.kodi/addons/script.skinshortcuts/default.py): the source file to load is "/home/osmc/.kodi/addons/script.skinshortcuts/default.py"
18:49:39 1203.754639 T:2911187952 DEBUG: CPythonInvoker(14, /home/osmc/.kodi/addons/script.skinshortcuts/default.py): setting the Python path to /home/osmc/.kodi/addons/script.skinshortcuts:/home/osmc/.kodi/addons/script.module.simplejson/lib:/usr/share/kodi/addons/script.module.unidecode/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat:/usr/lib/python2.7/dist-packages/gtk-2.0
18:49:39 1203.755127 T:2911187952 DEBUG: CPythonInvoker(14, /home/osmc/.kodi/addons/script.skinshortcuts/default.py): entering source directory /home/osmc/.kodi/addons/script.skinshortcuts
18:49:39 1203.755737 T:2911187952 DEBUG: CPythonInvoker(14, /home/osmc/.kodi/addons/script.skinshortcuts/default.py): instantiating addon using automatically obtained id of "script.skinshortcuts" dependent on version 2.20.0 of the xbmc.python api
18:49:52 1216.710815 T:2911187952 INFO: CPythonInvoker(14, /home/osmc/.kodi/addons/script.skinshortcuts/default.py): script successfully run
18:49:53 1217.726685 T:2911187952 INFO: Python script stopped
18:49:53 1217.727295 T:2911187952 DEBUG: Thread LanguageInvoker 2911187952 terminating
18:50:09 1233.747681 T:2652574704 DEBUG: Thread JobWorker 2652574704 terminating (autodelete)
18:50:28 1252.401367 T:2847085552 DEBUG: script.module.osmcsetting.updates : - blurp 863 - Home.xml
18:50:37 1261.318359 T:3004167152 DEBUG: CAESinkPi:Drain delay:99ms now:0ms
18:50:47 1271.319336 T:3004167152 DEBUG: CAESinkPi:Deinitialize
18:50:47 1271.321777 T:3004167152 DEBUG: CAESinkPi:SetAudioProps hdmi_stream_channels 0 hdmi_channel_map 00000000
18:50:47 1271.337402 T:3004167152 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.audio_render handle 0x4d2b190
There is no clear indication here of any error that would result in a Kodi crash. The last time any CEC reference was in the log was 81 seconds prior to the crash end of the log. While yes, CEC may have had some issue, it hardly seems to be the reason for the crash. You said yourself that disabling CEC still results in crash/freeze.
