This is a very time consuming process which I’d rather avoid – at this time, I wasted more hours on this than the Vero4K is worth; can you please explain what purpose that would solve? You have three sets of identical logs, what would this add?
usb 1-1: new full-speed USB device number 2 using xhci-hcd
xhci-hcd xhci-hcd.0.auto: xHCI host not responding to stop endpoint command.
xhci-hcd xhci-hcd.0.auto: Assuming host is dying, halting host.
xhci-hcd xhci-hcd.0.auto: Host not halted after 16000 microseconds.
xhci-hcd xhci-hcd.0.auto: Non-responsive xHCI host is not halting.
xhci-hcd xhci-hcd.0.auto: Completing active URBs anyway.
xhci-hcd xhci-hcd.0.auto: HC died; cleaning up
xhci-hcd xhci-hcd.0.auto: Timeout while waiting for a slot
As mentioned above, “lsusb” shows nothing – it locks while the USB driver resets, then it just shows the hubs (if even that).
The other adapter is not seen at all or even acknowledged to exist.
[ 34.885631] usb 1-1: new full-speed USB device number 2 using xhci-hcd
[ 44.895564] xhci-hcd xhci-hcd.0.auto: xHCI host not responding to stop endpoint command.
[ 44.895577] xhci-hcd xhci-hcd.0.auto: Assuming host is dying, halting host.
[ 44.914113] xhci-hcd xhci-hcd.0.auto: Host not halted after 16000 microseconds.
[ 44.914123] xhci-hcd xhci-hcd.0.auto: Non-responsive xHCI host is not halting.
[ 44.914129] xhci-hcd xhci-hcd.0.auto: Completing active URBs anyway.
[ 44.914153] xhci-hcd xhci-hcd.0.auto: HC died; cleaning up
[ 49.915509] xhci-hcd xhci-hcd.0.auto: Timeout while waiting for a slot
