Not sure from that snippet.
Make sure you build from osmc master.
this is the root /home/osmc/osmc/package/mediacenter-osmc. command is “sudo make rbp2”
echo the output of build to a log file. The real error could be many lines above the do you need to go back and look at the log.
that’s the full log:
http://paste.osmc.io/feyeqogito.mel
btw: firefox crashs by saving the pasted inputs.
can you see an other error inside the logfile?
On the last page:
patching file project/BuildDependencies/scripts/0_package.list
Hunk #1 FAILED at 17.
1 out of 1 hunk FAILED – saving rejects to file project/BuildDependencies/scripts/0_package.list.rej
Have a look at 0_package.list.rej and see what’s failed.
thx. step by step, i learn to understand the process.
in “rbp-000-krypton-backports.patch”
you have to replace the line
libass-542975a-win32-vc140.7z
by
libass-6aaaf5-win32-vc140.7z
that’s the commit
``https://github.com/xbmc/xbmc/commit/a9b24448a9c7c0aed1174e03ec5f5de68e1fe895
